Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
turbo vs super
Old May 10, 2008 | 03:10 AM
shawn5989's Avatar
Default turbo vs super
whats gonna give the most hp, and toruqe outta the turbo and super
Old May 10, 2008 | 09:28 AM
24boosted's Avatar
Default Re: turbo vs super (shawn5989)
Old May 10, 2008 | 09:59 AM
i-VTEC_DOHC's Avatar
we'll make this easy for him.
turbo>super.
turbo gives u more power up top but the bottom has turbo lag. supercharger isnt as good up top but very good bottom end. but the sc doesnt put out as much power cuz its belt driven fi
Old May 10, 2008 | 12:54 PM
Curiouz_G's Avatar
Default Re: (i-VTEC_DOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC &raquo;</TD></TR><TR><TD CLASS="quote">we'll make this easy for him.
turbo&gt;super.
turbo gives u more power up top but the bottom has turbo lag. supercharger isnt as good up top but very good bottom end. but the sc doesnt put out as much power cuz its belt driven fi</TD></TR></TABLE>
actually it can vary depending on the application. Look at a SC on a s2000. you dont gain much down low but gain ALOT after vtec engages. as for the turbo, you could have a hybrid BB turbo which allows for quick spools low end that wont run out of breath on the topside either.
Old May 10, 2008 | 03:09 PM
dirtySOHC's's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn5989 &raquo;</TD></TR><TR><TD CLASS="quote">whats gonna give the most hp, and toruqe outta the turbo and super</TD></TR></TABLE>
turbo
Old May 10, 2008 | 03:16 PM
tooann's Avatar
Boooo... Thought u were gonna give us a video of a Turbo Si vs. SC'd Si.
Old May 10, 2008 | 08:36 PM
FlatlineSI28's Avatar
turbo FTW
Old May 12, 2008 | 07:23 PM
knaira112387's Avatar
ftw. turbizzle and its a lot cheaper!!!
Old May 23, 2008 | 02:02 PM
turillo's Avatar
No Questions asked...Turbo is the way to go for the most power. Especially with cars like hondas that have good flowing heads and carry power all the way to redline.
Old May 23, 2008 | 02:05 PM
JchanFTW's Avatar
Oh the answer is quite simple my dear friend, NA is best.
Old May 23, 2008 | 04:02 PM
24boosted's Avatar
Default Re: (JchanFTW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JchanFTW &raquo;</TD></TR><TR><TD CLASS="quote">Oh the answer is quite simple my dear friend, NA is best. </TD></TR></TABLE>
Oh but of course.... I agree with JchanFTW but I would never take this out for what he's got under the hood. lol Most people never make it to a full NA build, they just keep promoting NA is best yet stop at I/H/E/reflash. NA is best if you can afford a 7-10 grand build, bottom up just to come close to the power turbo makes at only 4-5.
Old May 23, 2008 | 04:15 PM
JchanFTW's Avatar
Default Re: (24boosted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24boosted &raquo;</TD></TR><TR><TD CLASS="quote">
Money is usually the limiting factor, good point. However, it always makes me so sad to see how tight the engine bay is for our cars. I'd do a full wire tuck on my car if I had a daily driver.
Old May 24, 2008 | 09:52 AM
24boosted's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JchanFTW &raquo;</TD></TR><TR><TD CLASS="quote">However, it always makes me so sad to see how tight the engine bay is for our cars. I'd do a full wire tuck on my car if I had a daily driver. </TD></TR></TABLE>
...... uhhh.... ok so turbo FTW.
Old May 24, 2008 | 02:40 PM
Default Re: (aboi744)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aboi744 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
stop trying to boost your post count lame-o. this is the 5th thread with a reply
Old May 24, 2008 | 03:58 PM
JchanFTW's Avatar
Default Re: (dirtySOHC's)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtySOHC’s &raquo;</TD></TR><TR><TD CLASS="quote">
stop trying to boost your post count lame-o. this is the 5th thread with a reply</TD></TR></TABLE>
Old May 24, 2008 | 04:42 PM
xkrntamax's Avatar
from my knowledge, turbo needs to have bolts-on.(im talking about for turbo bolts on.)
How about SC? does SC needs bolts-on too?
Old May 24, 2008 | 05:25 PM
Default Re: (xkrntamax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xkrntamax &raquo;</TD></TR><TR><TD CLASS="quote">from my knowledge, turbo needs to have bolts-on.(im talking about for turbo bolts on.)
How about SC? does SC needs bolts-on too?</TD></TR></TABLE>
not exactly. technically a turbo system is not a a true bolt on because you don't just install the parts by simply "bolting on" them on. there are oil lines and vacumm lines that need to be ran and possibly wiring for emange or Fi/C (since FG's/FA's dont have a programable ECU yet) the only real thing left that can be bolted on in addition to the turbo system is the exhaust system. but really the exhaust is just an extension of the turbo system and not really a part of it.
if you have a supercharger then you can still have "bolt on" parts. i.e. I/H/E
Old May 24, 2008 | 05:57 PM
Westrock2000's Avatar
It comes down to this.
Superchargers are generally easier to install because they are usually one part (assuming its a roots style). Plus its at the top of the car which is easier to get to. HOWEVER because of the way roots function they can move a ton of air, but not at high pressure ratios (boost/PSI) without making the air very hot. Therefore a roots supercharger, no matter the size will generally not be able to exceed 8-10 PSI safely without an intercooler. Anything under that and they are excellent in just about every regard. But once you add in the intercooler you are taking away from the simplicity that makes the roots so practical and affordable.
Turbo's however are far more effecient at higher boost levels. So there fore by design a turbo is better for high power where you are needing considerable boost pressure. But they are more complex and require more parts.
Its a trade off, just have to choose which you want. Turbo's are going to win for outright power, but for normal full RPM range driving superchargers have advantages.
00pr3lude
Apr 4, 2008 06:09 PM
23hatchturbo
Jan 10, 2008 09:47 PM
Demonis
10
Aug 12, 2006 05:58 PM
CivicSmkYa21
May 19, 2004 10:06 AM
krings
May 9, 2003 01:26 AM
