good setup?
Old May 9, 2008 | 05:38 PM
vargas's Avatar
Default good setup?
hello, i am going to upgrade my suspension and wanted to hear some opinions .
This is going into a DD with occasional track visits.
Ground control coilovers with Tockico "Blue" shocks
ASR rear subframe brace and 24mm swaybar
skunk2 LCA's and Beaks lower arm bar
this is a pretty complete setup right? or
Old May 10, 2008 | 09:25 AM
vargas's Avatar
BUMP
is a 24mm sway bar too much for a daily driver? understeer, oversteer ??
Modified by vargas at 10:52 AM 5/10/2008
Old May 10, 2008 | 08:21 PM
RedRocketDX's Avatar
Default Re: good setup? (vargas)
24mm is probably going to be overkill.
I have an 22mm EX front and a 19mm rear and it is perfectly balanced.
Old May 10, 2008 | 09:33 PM
evndrkr's Avatar
anything bigger than his setup may cause the rear to consistently break out. you probably wont need the beaks bar if you have the subframe brace. everthing else sounds good.
MoE JdM
Aug 5, 2007 09:09 AM
threesixes
16
Feb 24, 2007 05:30 AM
solo-x
Jan 8, 2003 04:18 PM
ill phil
11
Dec 16, 2002 02:15 PM
96 SOHC VTEC
Jun 12, 2002 11:09 AM
