transmission or engine noise?
Old May 9, 2008 | 04:44 PM
marecco's Avatar
Default transmission or engine noise?
Alright i have a noise that im not sure if it is normal or something of concern. its kinda a hard noise to explain but it occurs when i am driving a certain mph take 60 for example and i left off the gas and let the car coast and start to slow down i hear a noise that sounds similar to a throwout bearing grind churn sound. is this a possible issue here the throwout bearing? or is it something else? btw the motor is a JDM b16 with b16 trans. about 40k miles stock clutch. thanks for any help
o and the noise only occurs when the clutch is disengaged and when decelerating if i accerate it goes away
Modified by marecco at 8:50 AM 5/10/2008
Old May 11, 2008 | 12:24 PM
marecco's Avatar
bump
Old May 14, 2008 | 03:33 PM
marecco's Avatar
i have been told from a bmw tech i work with as well as another source that it is prolly gear noise. and that i hear it due to the fact that i have billet mounts with poly bushings. is this possible and thus make it a non issue.
1clean01
Honda Civic (2001 - 2005)
May 2, 2012 08:11 PM
wtsapexipowerfc
Transmission & Drivetrain
Mar 5, 2011 06:41 AM
DXH
Oct 1, 2006 11:55 AM
RS1995
Jan 6, 2002 12:26 PM
