Will these springs fit my 98 Civic?
if you have a DX (lighter) model with a sohc engine in it, the springs will raise the front like 5 inches higher than the back. It's because the SI is heavier and has a heavier engine, so the front springs are stiffer, and maybe longer.
Trust me, I know from experience.
I used stock ITR springs on my 97 DX and it lowered the car about half an inch all around, with no front end problems... oddly enough. And they were the best springs ive ever had..
I like the close-to-stock look
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wazup »</TD></TR><TR><TD CLASS="quote">if you have a DX (lighter) model with a sohc engine in it, the springs will raise the front like 5 inches higher than the back. It's because the SI is heavier and has a heavier engine, so the front springs are stiffer, and maybe longer.
I like the close-to-stock look</TD></TR></TABLE>
I have a Civic HX, which I think is a lighter model with a lighter engine. So, I suppose the front end will end up higher than the back!
Modified by rhgindc at 7:05 AM 5/10/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhgindc »</TD></TR><TR><TD CLASS="quote">
Modified by rhgindc at 7:05 AM 5/10/2008</TD></TR></TABLE>
yeah, most likely. I'd say just play it safe and get ITR springs, they dont lower your car that much and they are stiffer than the SI ones.. but not crazy stiff or anything, still pretty comfortable..
just a suggestion
just a suggestion
xd69
Sep 30, 2004 11:39 PM
