Need help with timing/compression question
Old May 9, 2008 | 12:44 PM
ca-rs's Avatar
Default Need help with timing/compression question
If a d16z6 is out of time, would it mess with compression test readings?
Old May 9, 2008 | 12:53 PM
wonder squirrel's Avatar
Default Re: Need help with timing/compression question (ca-rs)
If the valve timing is off, yes. But it would read the same across the board, if you have only one or two cylinders with low compression, then its likely some other cause.
Panoply
14
Jun 5, 2012 07:38 AM
Samuels
May 26, 2007 08:34 PM
TurboJesse
Sep 23, 2003 06:20 PM
