Crx running lean causeing low rev limit
Old May 9, 2008 | 12:22 PM
BlakeJ53's Avatar
Default Crx running lean causeing low rev limit
91 CRX SI b16 swap rebuilt the whole motor.... We drove it for over 1000 miles with no problems We thought we blew the clutch so I pulled the motor and put it back together it turned out to be a bad clutch cable. Now the motor when in gear wont rev past 5500 when the gas is floored. When I use partial throttle it will go past 5500 slowly. I have changed the dizzy with a brand new one and cap and rotor and plugs and wires. Still no luck the plugs are turing white really quick. PLEASE HELP
Old May 9, 2008 | 03:17 PM
traxxasx's Avatar
Default Re: Crx running lean causeing low rev limit (BlakeJ53)
thats when vtec kicks in.
Im sure its stuttering and sounds like its redlining.
Check all things for vtec.
Also reset ecu by taking battery off for a minute.
Old May 9, 2008 | 05:31 PM
Hanmin's Avatar
try reving it up without vtec connected.
Old May 31, 2008 | 05:20 PM
CRex_22's Avatar
reving it with the vtec unpluged didn't help. the problem still stands
Old Jun 2, 2008 | 10:18 AM
CRex_22's Avatar
bump for more help please!!
Old Jun 2, 2008 | 11:19 AM
rice_classic's Avatar
Default Re: (CRex_22)
Codes?... When having a problem this should be the FIRST thing you check for.
It sounds as if the problem is in the ECU either the ECU itself or something sending information to the ECU
Old Jun 2, 2008 | 11:57 AM
CRex_22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice_classic &raquo;</TD></TR><TR><TD CLASS="quote">Codes?... When having a problem this should be the FIRST thing you check for.
It sounds as if the problem is in the ECU either the ECU itself or something sending information to the ECU</TD></TR></TABLE>
it is a solid cel, the ecu code. but i've tried 3 different ecu's and they all didn't work in the crx but they worked in my turbo'ed eg with a d15b.
jeffruby
13
Mar 19, 2006 12:19 AM
Got Milk
Dec 30, 2005 08:13 AM
slow91crx
Aug 30, 2005 04:43 AM
civicnar
Dec 6, 2004 03:12 PM
shiithook
13
Apr 30, 2002 06:43 PM
