ls crank and rods in a b16 block?
Old May 9, 2008 | 09:52 AM
dc4b20's Avatar
Default ls crank and rods in a b16 block?
like the title says, will this setup work? i did research but there is little on this topic. would that be the same as stroking the b16?
Old May 9, 2008 | 09:56 AM
Rickdrizzle's Avatar
nooooooooooooooooooooooes
Old May 9, 2008 | 09:58 AM
dc4b20's Avatar
Default Re: (Rickdrizzle)
explain
Old May 9, 2008 | 10:23 AM
i meant no, don't do it.
it'll work. look into the tech43 kit.
Old May 9, 2008 | 10:47 AM
dc4b20's Avatar
i was planning on doing a lsvetc build so i bought a b16 long block for a really good price. i also bought eagle rods and arias pistons. a guy i work with has a ls crank that he will sell me for like 50 bucks. wouldnt that setup be just as good as a lsvtec setup if not better?
Old May 9, 2008 | 12:36 PM
dc4b20's Avatar
Default Re: ls crank and rods in a b16 block? (dc4b20)
will this work?
Old May 9, 2008 | 04:05 PM
dc4b20's Avatar
Old May 9, 2008 | 04:48 PM
deftonerider's Avatar
yeah i've seen it done its the way to make a 1.9L with a b16 stamp on it and take peoples money
Old May 9, 2008 | 06:34 PM
boost'd_crx's Avatar
the ls crank will fit into the b16 block, but you will need to get custom rods for the setup.
Old May 9, 2008 | 08:51 PM
I AM WEASEL's Avatar
Default Re: ls crank and rods in a b16 block? (boost'd_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost’d_crx &raquo;</TD></TR><TR><TD CLASS="quote">the ls crank will fit into the b16 block, but you will need to get custom rods for the setup. </TD></TR></TABLE>
x2
This is because the deck height is different between the b16 and the b18a/b. You are essentially making a stroker motor; for ease of parts availability - getting of the shelf parts rather than getting custom parts made and waiting long lead times -your best bet would be to get a b18 block if you want to have a stroke of 89mm (stock ls stroke).
Old May 10, 2008 | 07:14 AM
Dogginator's Avatar
Daisy... Daisy...
The B16A block has a lower deck height than a B18 block. The B16B (CTR) block would work since it is the same as the GSR and ITR block.
Old May 10, 2008 | 08:12 AM
dc4b20's Avatar
Default Re: ls crank and rods in a b16 block? (Dogginator)
cool. thanks guys
CTR_B
Nov 9, 2008 05:54 PM
CTR_B
Oct 17, 2008 04:19 PM
dc4b20
May 9, 2008 12:46 PM
NOman0608
Mar 16, 2008 06:57 PM
CircuitFG
May 4, 2005 01:19 AM
