want fuel presure on talon injectors ??
Old Jul 14, 2002 | 09:07 AM
89dxhunchback's Avatar
Default want fuel presure on talon injectors ??
I've been trying to tune the car with my apexi afc, but in can't seem to take enough fuel away, so I put an adjustable FPR on now, how much fuel presure should I run, with the apexi at stock settings ??? Stock pump, pm6, talon injectors (450cc)...
No forced induction ( yet ), just a lowly 75 shot ( TORQUE !!! )...
I know the stock pump will fall off at 62 psi ( on the spary ), but it will ALWAYs stay steady at 44psi at wot ( stock FP )...
All I'm worried about right now is the car, running good on the motor after the talon injecotrs ( NOS isn't a consern right now .).
[Modified by 89dxhunchback, 7:32 PM 7/14/2002]
Old Jul 14, 2002 | 09:45 AM
Tbone's Avatar
Default Re: want fuel presure on talon injectors ?? (89dxhunchback)
Are you running forced induction?
Old Jul 14, 2002 | 09:55 AM
-TJ's Avatar
-TJ
Default Re: want fuel presure on talon injectors ?? (Tbone)
I don't think your stock pump is going to be able to maintain the pressure. I had 310's and on the dyno the fuel pressure slowly fell off.
With a better pump (walbro, bosch), you'll be ok.
I've got 450's and a Zdyne gold running 9psi. Idle FP is 25psi, full boost is 48. That's with the vac hose on.
Mr.Death
Jun 22, 2005 01:12 PM
Anubyss
Apr 23, 2003 06:54 AM
HybridCoupe
Jul 6, 2002 04:44 AM
ceemarun
May 29, 2002 02:18 PM
Mr. Softee
Mar 6, 2002 05:28 PM
