a/c work but isn't blowing or even with out a/c
Old May 8, 2008 | 06:52 PM
immajackuup's Avatar
Default a/c work but isn't blowing or even with out a/c
it started when i was hauling *** on the street next thing my fan stop blowing even with out the a/c on.
my uncle told me to check for the fuse fan before i start putting a new fan in.
where do i check for the fuse for the fan?
is there a number on the fuse that is for the fan?
i hope its just the fuse instead of the fan.
Old May 8, 2008 | 06:55 PM
IM **** OFF BECAUSE IT WAS REALLY HOT TODAY IN HOUSTON!!!
Old May 8, 2008 | 07:29 PM
kingSfit's Avatar
under tha hood fusebox
Old May 8, 2008 | 07:41 PM
Default Re: (kingSfit)
will it tell u where does the fuse goes to?
Old May 8, 2008 | 07:52 PM
ReactioN's Avatar
* B A N N E D *
Default Re: (immajackuup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by immajackuup &raquo;</TD></TR><TR><TD CLASS="quote">will it tell u where does the fuse goes to?</TD></TR></TABLE>
Dude.
Go check
and yes it should.
Old May 8, 2008 | 08:01 PM
Default Re: (ReactioN)
lol i haven't check yet because its dark outside
Old May 8, 2008 | 08:42 PM
Default Re: a/c work but isn't blowing or even with out a/c (immajackuup)
i found the diagram for my 2000 civic
https://honda-tech.com/zerothread?id=1966666
but i still don't know what fuse is it.
is it call a/c heater or blower motor relay?
Old May 8, 2008 | 08:51 PM
g1itchgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by immajackuup &raquo;</TD></TR><TR><TD CLASS="quote">i found the diagram for my 2000 civic
is it call a/c heater or blower motor relay?</TD></TR></TABLE>
yes sir, a/c heater or blower motor relay easy as that. btw you should have that diagram on your fuse box cover(if you dont know where you fuse box is, its next to your battery)
Old May 8, 2008 | 08:56 PM
oh im talking about the fan inside the car i think its under the dash on the passenger side.
because thats the only thing that blow the cold a/c inside my car right?
Old May 8, 2008 | 09:19 PM
p10hlm's Avatar
and this is only the start of the heat in h-town
check your resistor for the fan
Old May 9, 2008 | 08:03 PM
Default Re: (p10hlm)
yo penny my resistor doesn't look burnt when i open it up.
I check the heater fan fuse under the hood and it look fine also.
but for some reason my fan work now after i check the fuse and resistor that was fine.
what could make it go out and come back on out of no where?
Old May 10, 2008 | 06:04 AM
95dxsir2's Avatar
sounds like a loose connection @ the blower resistor, put some di-electric grease on the connections.
Old May 10, 2008 | 07:30 AM
is it those stuff i see on my headlight wires?
Old May 10, 2008 | 07:34 AM
95dxsir2's Avatar
probably, that white lookin crap, parts stores will sell it
demiseraph
Aug 5, 2011 05:12 PM
Lil_Wyte
Jun 7, 2010 07:35 PM
trustdestruction
Mar 30, 2009 03:11 PM
honda_racer1986
Jan 23, 2006 06:46 PM
b00sted4dr
Jul 25, 2005 05:28 AM
