Crank pulley
Old May 8, 2008 | 06:52 PM
driftam1's Avatar
Default Crank pulley
any body that has ever taken a crank pulley of how did you take it off and wat is the easyest way this thing is on tight!!!!
Old May 8, 2008 | 07:30 PM
zrickety's Avatar
Default Re: Crank pulley (driftam1)
i used a small prybar at the flywheel teeth underneath to hold it, then use a 1/2" breaker bar or ratchet with a pipe or cheater bar for leverage on the bolt. it should come loose. the hardest part is holding the flywheel
Old May 8, 2008 | 07:37 PM
garageEF's Avatar
Default Re: Crank pulley (zrickety)
there are a few ways to get that bitch off....
the easiest is to befriend someone with air tools and use a 1/2 impact but some of us arent so lucky
i would suggest connecting a chain to a hole in the pulley..and the other end to the steering tie rod. ive used this method and it will work if you're patient and have some imagination.
best of luck and try not to hurt yourself in the process
Old May 8, 2008 | 08:02 PM
ahglaze1's Avatar
i got one of these http://www.amazon.com/gp/product/B0000TMLWQ/ref=pd_cp_hi_0/102-3334439-0887336?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-41&pf_rd_r=1NBMPS1MCSFWWZC0AJ9M&pf_rd_t=201&pf_rd_ p=277661601&pf_rd_i=B000L7O4FE
wedge it aginst the frame and take a 1/2 ratchet with a cheater bar on it and give it a good pull. works every time with that tool i have had zero problems.
sean burke
May 6, 2009 08:15 AM
Xscort
Jul 25, 2008 10:54 PM
budomove
Nov 2, 2007 07:26 AM
projectjazzmine
Jan 20, 2007 08:55 PM
MustangPunk302
Nov 25, 2003 10:47 PM
