Is there any way to get OEM fog light replacement parts?
I installed my fog lights the other day and cross threaded the screw that holds the garnish over the lights. What I need are 2 new screws and the bracket that it screws into.
Is there any way I can get just those parts? What do I do?!
try goin to your local honda dealer..they should have what u need
I had to wire in a relay manually. Bummer. I wanted stock Honda (when I bought the fogs, I didn't want to pay $300 for the stockers, and really wouldn't want to now either).
Shawn
http://www.hondaautomotiveparts.com/...IES+-+EXTERIOR
This link might be to long. If it is go to http://www.hondaautomotiveparts.com
select honda parts then pick your car and all that other stuff then when is says
chose system component click on Accessories Exterior
They have some of the pieces listed for the fog light kit I did not see the screws thou
Something I didn't think of here:
Which Civic foglight kit?
I have a 1992.
Which one does Buzzbomb have?
You posted a link for 1995 Civic Si.
The foglight kits for the 1992 and 1995 are DIFFERENT. 107517 for the 1992, 107518 for the 1995. The part numbers at Honda are also different.
So, Buzzbomb, what foglight kit are you looking for?
Shawn
I have a 1992.
Shawn
I have the 99'-00' Foglights.
I'm going to try the dealer but I'm afraid that they won't be able to just get single parts. The other avenue is trying to find someone that has a car that was in an accident and I could get the parts from them. Only problem with that is, is timing.
Shawn
You might be right. If you have the parts diagram, they might be able to help you. Did you save the instructions?
Shawn
Shawn
yeah i saved the instructions. i will try the dealer next week when i get some free time. i'll hope for the best. if that falls through, i will be back on here trying to find something else.
K20Alex
Apr 22, 2008 02:25 AM
