HEEEELPPPP!!!!!!!!!!!!!!! im changing my suspension right now!! need help!!!
Old May 8, 2008 | 05:27 PM
soodominican's Avatar
Default HEEEELPPPP!!!!!!!!!!!!!!! im changing my suspension right now!! need help!!!
can anyone show me any good threads about changin shocks and springs on a DA? im going to put in tein s.tech's and tokico blues from a ef...HELP!!!
Old May 8, 2008 | 05:45 PM
92integraVTECgsr's Avatar
Default Re: HEEEELPPPP!!!!!!!!!!!!!!! im changing my suspension right now!! need help!!! (soodominican)
how do you NOT know how to change the shocks and springs. If you don't know how, you should not be attempting this job. Or you should have researched this before you started this job.
But I'll give you a few hints.
Fronts:
1. Take out the damper pinch bolt on the fronts.
2. Take out the bolt holding the shock fork to the lower control arm.
3. Take off the 2 shock mounting nuts in the engine bay.
Rears:
1. Take out the lower shock bolt.
2. Take off the 2 shock mounting nuts in the rear hatch section.
Honestly, if you don't have the common sense to figure it out, just pay someone to do it.
Or go buy yourself a Haynes manual from Autozone. It will be your best $20 every spent.
Good luck.
Old May 8, 2008 | 06:05 PM
Default Re: HEEEELPPPP!!!!!!!!!!!!!!! im changing my suspension right now!! need help!!! (92integraVTECgsr)
uh oh
Old May 8, 2008 | 06:08 PM
thhat bolt is a pain in the *** man it comes loose but wont get out
Old May 8, 2008 | 08:29 PM
SkaiWu's Avatar
http://youtube.com/watch?v=sP52K8O2MSg
this is not a integ but it give you basic idea watch it lol
Old May 8, 2008 | 08:43 PM
rufridn's Avatar
for a dc, but maybe it'll help.
http://www.team-integra.net/se...D=494
Old May 9, 2008 | 05:20 AM
lmike6453's Avatar
took me 9 hours to change all 4 springs on my dc4 and needed an air compressor to get off stuck bolts on strut tower...
biggest safety tip is watch out for the spring and bolt from flying and hitting someone and/or someone's car
Old May 9, 2008 | 06:42 AM
AlphaQup's Avatar
Default Re: (lmike6453)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 &raquo;</TD></TR><TR><TD CLASS="quote">took me 9 hours to change all 4 springs on my dc4 and needed an air compressor to get off stuck bolts on strut tower...
biggest safety tip is watch out for the spring and bolt from flying and hitting someone and/or someone's car</TD></TR></TABLE>
I guess you've never heard of spring compressors lol. They rent em for free, I believe at PepBoys and Autozone. And 9hrs, good lord.
Old May 9, 2008 | 06:58 AM
Default Re: (AlphaQup)
GOOD LORD!!! lol.. thats crazy. newbs.. gotta love them...
SERIOUSLY!!!! everyone that does NOT know what they are doing, go get a HAYNES Manual for your car. They cost $20 from Autozone. It will teach you everything you know.
It took me 2hrs max when I had my 92 GSR and now I can change my shocks and springs on my 00 GSR in less than an hour. And I am not using an air compressor or impact gun. Buy or rent a spring compressor for around $15.
It really is NOT a hard job. It is VERY simple.
Old May 11, 2008 | 11:22 AM
Default Re: (92integraVTECgsr)
i gave up cuz some bolts are tooo too hard to get off, i hit em with the impact gun and nothin so im just going to save my money go to my local honda dealer and order all those bolts new to make my life a lot easier. i'll destroy the ones that're rusted on
Old May 11, 2008 | 11:25 AM
Default Re: (soodominican)
If they are rusted on, yes you will need new bolts.
Get a grinder and put a cutting wheel on it and cut the nuts off the end and hammer the rest of the bolt out. It should only be the 4 big bolts on the lower control arm. The rest of the bolts should come out.
Marvin1985
Mar 19, 2012 04:26 PM
DeDonDeRosa
Mar 15, 2009 06:21 AM
corkss
Sep 25, 2008 06:21 PM
sohc_student
Suspension & Brakes
Sep 4, 2006 11:05 PM
Got Utensils
11
Mar 10, 2004 06:37 PM
