Transmission problems..syncros or clutch?
Old May 8, 2008 | 05:08 PM
be18see1's Avatar
Default Transmission problems..syncros or clutch?
My friend's B16A2 tranny has been having some problems. It is very very difficult to put it in or out of gear, even when the clutch pedal is to the floor. You have to double clutch to get it in or out any gear and it grinds some even then. The transmission is in a a 90' crx with the Hasport clutch conversion. It has been adjusted correctly. The clutch was changed pretty recently (about 15k miles) to an Exedy stage 1 and pressure plate. We haven't been able to pull it yet but I was just looking for some different ideas. I didn't think the syncros would go out in every gear.
Old May 8, 2008 | 09:59 PM
be18see1's Avatar
Default Re: Transmission problems..syncros or clutch? (be18see1)
night bump
Old May 9, 2008 | 05:44 PM
Aquafina's Avatar
I highly doubt it is either the synchros or the clutch.
Old May 9, 2008 | 06:34 PM
be18see1's Avatar
Default Re: (Aquafina)
what would it be..gears? it just started doing it within a 500 mile span, making it virtually undriveable.
Old May 9, 2008 | 07:28 PM
Aquafina's Avatar
Something with the engagement setup, shift forks, bearings, sliders, synchro hubs, etc.
Old May 9, 2008 | 08:45 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
so it was working at one point, but now has issues after good driveability? was there ALWAYS sufficient fluid? meaning never ran dry from a leak? and you do have good pressure from the pedal to the slave??? make sure the release fork is moving. with the motor off, how does it shift through the gears? if it shifts smooth through with motor off, then it's prob clutch related. if it's hard with motor off, it's probably internal...with relation to the parts aquafina mentioned.
Old May 9, 2008 | 10:19 PM
Aquafina's Avatar
IIRC the HASport cable conversion retains the cable. Just uses a mechanism to control the clutch fork.
Old May 10, 2008 | 07:15 AM
be18see1's Avatar
ill have to give him a call and check it out. ill be back with an update. as i said, its not my car.
Old May 10, 2008 | 07:28 AM
KevinT707's Avatar
Sounds exactly like the problem I had in my CRX except I'm still running a cable tranny. It was VERY hard to shift every gear & I double clutching made it slightly easier to go into gear.
It ended up being the clutch disc/PP - the springs popped out of the disc and a piece of it was lodged into the PP fins.
Old May 10, 2008 | 10:16 AM
be18see1's Avatar
Default Re: Transmission problems..syncros or clutch? (not so civic)
to 'not so civic' this is the owner of the CRX and when the car is off, it shifts smoothly. There's no problem in getting it through the gears. There has not been a leak in the transmission. I can check though, but I'm really positive there hasn't been one. And the fork does move back and forth.
to Kevin, I'm kind of hoping that's what the problem is. So it's not that expensive of a fix.
Also one more question, I've tried everything possible to get a little free play in the clutch pedal. Could that be a small reason why this has occurred over time? and it's finally bitten me in the ***.
Old May 27, 2008 | 11:04 PM
TonyRomo's Avatar
this happened to me in my civic and it ended up being there was no break fluid in the system, had to bleed it and add new fluid. im guessing you already checked that tho.
Old May 28, 2008 | 09:42 AM
be18see1's Avatar
Default Re: Transmission problems..syncros or clutch? (TonyRomo)
its in a crx, so there is no hydraulic system. its a cable clutch. also, just so you know, its brake fluid.
Old May 28, 2008 | 05:33 PM
TwinOptiX's Avatar
When you installed the flywheel, did you use Loctite on the flywheel bolts? Did you torque them to spec?
Old May 28, 2008 | 05:38 PM
be18see1's Avatar
Default Re: (TwinOptiX)
i didnt install it, but ill ask.
snzh22
Apr 29, 2008 09:22 AM
snakepirates
11
Jun 9, 2006 01:40 PM
turbotime
14
Oct 22, 2004 12:14 AM
MiraiZ
Aug 12, 2003 06:18 PM
ImpulseITR
Jul 23, 2003 09:38 PM
