front brake caught fire!
ok so I purchased a car around 3 months ago and did a swap on it etc etc.... So today was my first test drive on it and when I was returning home, the car started slowing down and i smelt the brakes where burning. It was like driving and braking ad the same time. I saw smoke too. The pedal was all the way up and there is no travel at all now...
So I arrived home and I saw that my driver side (front) caliper was on fire. I was like WTF and immediately took the hose and sprayed water because I wont risk my new swap for some rotors/calipers...... I know that I will have to replace my rotors too since they might be warped.........
Since I dont have any experience with the car, I dont know if its the bb, the mc, or the calipers.......
any help?
any help?
was the brake fluid leaking? it could be leaking from a caliper seal or hose right on to the super hot rotor making an instant fire, just a guess. get it fixed asap
I dont think it was leaking....
The car drove fine untill the gas station and once I drove on reverse for a second then they got really stuck!
Modified by JUN. at 9:31 PM 5/8/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs »</TD></TR><TR><TD CLASS="quote">caliper is prob locked.. just replace it. and rotor </TD></TR></TABLE>
x2
i've seen a frozen caliper before...i would inspect the passenger side and the rears and clean it/lube it as necessary. it may happen again elsewhere
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zrickety »</TD></TR><TR><TD CLASS="quote">
x2
i've seen a frozen caliper before...i would inspect the passenger side and the rears and clean it/lube it as necessary. it may happen again elsewhere</TD></TR></TABLE>
will do,,,,, do you guys know around how much do the calipers cost? like on autozone
x2
Dont you guys think that it could be the MC ? I mean i think I also saw the rear calipers smoking too.... I think that the MC is not pulling off the fluid from the lines when the brake pedal is released....
Im gona change the caliper that caught fire, new pads, change the MC and resurface the rotors to see how it goes.....
You got drums in the back, unless you swaped for disc.
Jack the car on all 4, have somone push the brakes with the car on, while you see if the wheels lock up. Then have the person release brakes, and see if any of the wheels are still locked.
If not, just replace ur caliper and pads.
Also resurface the rotor.
it sounds more like the master if all the wheels are locking up, did you mess with the rod inside the booster? I would swap back the stock master and see if anything changes
Hey i got calipers and rotors you can buy. The rotors are brand new drilled slotted all that good stuff. I got them with the car but i did 94 brake upgrade. Lemee know
KOALA YUMMIES
May 1, 2010 08:23 PM
GOOCH-JDM-ITR
Dec 23, 2006 08:49 AM
hooptie157
Feb 26, 2003 05:42 PM
