Need help with EXHauST!!!!
Old May 8, 2008 | 04:15 PM
red02s2k's Avatar
Default Need help with EXHauST!!!!
Ok guys I have a boosted teg I am triing to build a aluminum exhaust but the fun is the parts my down pipe is stainless and the rest I want to be aluminum. Already have the piping what I need is some hangers to weld to the aluminum and some kind of flang to weld to the aluminum that i could match up with the down pipe. Can anyone help b/c tony is busy tell june can't wait!!!!
Old May 8, 2008 | 05:06 PM
ScorpioMk's Avatar
Default Re: Need help with EXHauST!!!! (red02s2k)
normal v-bands for the exhaust or could make it slip fit also. hangers just bend your own or use some steel clamps around the exhaust and weld hangers to that.
Marcus
Old May 8, 2008 | 06:11 PM
red02s2k's Avatar
thanks i was thinking about that i just wanted to see what everone had out there
Old May 8, 2008 | 06:20 PM
ScorpioMk's Avatar
Default Re: (red02s2k)
if you do a search of aluminum exhausts theres a few threads with good pics of the hangers they used/made or suggestions they were givin. GL
Marcus
redboost10's Avatar
http://www.racepartssolutions.com
they have the cheapest v-band kits ive found.
Old May 8, 2008 | 06:30 PM
red02s2k's Avatar
ok guy's i have been searching on h-t. The website you gave only has a 4or5 inch v band i need a 3 inch
Old May 8, 2008 | 07:26 PM
manifoldmiketyson's Avatar
http://www.youngsperformance.c...dkits
you have to buy your steel v-bands there too. v-bands are not all the same. make sure you don't mix brands. you can get aluminum with or without o-rings.
put hangers on the muffler and the downpipe if you can.
if you have to make a hanger on the aluminum and want it to be as strong as steel. make a steel hanger and then either bolt or t-bolt the bracket to the pipe.
other guys use supported aluminum rod.
Old May 8, 2008 | 08:07 PM
red02s2k's Avatar
so check this do you guys think this would work how i found this i don't no i guess lucky
http://cgi.ebay.com/ebaymotors...7.m32
Old May 8, 2008 | 11:10 PM
redboost10's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redboost10 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.racepartssolutions.com
they have the cheapest v-band kits ive found. </TD></TR></TABLE>
sorry i didnt know they didnt have 3" kits, but the reason i posted this site was because they mix-match just like what they do on that ebay site you have, which saves you a lot of money obviously.
Old May 9, 2008 | 05:08 AM
red02s2k's Avatar
ooo ok cool thanks on that site
speedlabx2005
Oct 6, 2006 06:43 AM
GSteg
Welding / Fabrication
10
Jul 31, 2005 03:39 PM
Race Egr
Jun 17, 2005 07:48 AM
rough_draft
Nov 17, 2004 06:07 AM
fsp31
Jun 29, 2002 06:46 AM
