exhaust valve seal on intake side YES NO
Is it possible to put an exhaust valve seal on the intake side? Yes/No, if not. Why not? I know OEM has different, I just was wondering if it could be done or not.
Thanks
Thanks
what model , I know d series I did today all the same
honda has alot of crossover numbers , today's had 3 different #'s and 1 was different color.. , called , nunbers crossed over
It's for a B16 head. Well I have two vendors I'm considering buying from. 1 says its okay and that it's better because it has higher heat tolerances. Then the other, selling a super tech brand, says that it does make a difference. So I don't know. OEM honda list them separately but I don't know what the part numbers are. Anybody else know?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sorrule »</TD></TR><TR><TD CLASS="quote">It's for a B16 head. Well I have two vendors I'm considering buying from. 1 says its okay and that it's better because it has higher heat tolerances. Then the other, selling a super tech brand, says that it does make a difference. So I don't know. OEM honda list them separately but I don't know what the part numbers are. Anybody else know?</TD></TR></TABLE>
supertech does list 2 different part #'s for the intake and exhaust side valve stem seal FYI -- i am not sure if they are interchangable, never really thought about it
why not just get the correct ones you need and not worry about mix matching them ?
I know it's something very little but I already bidded on all ext side seals from a vendor who says it works. I'm saving about $10 which is not much, but I can't justify spending that much for little seals. Whatever, the part number from auto part stores are also the same I found out, so I'm just gonna run it. I'll let you guys know haha.
8krdline
Oct 4, 2007 04:32 AM
Toadfart
11
Feb 17, 2006 07:09 AM
