Concerning best ECU for Turbo application on my H23
Old May 8, 2008 | 03:18 PM
TheOdd001's Avatar
Default Concerning best ECU for Turbo application on my H23
So I have a 93' H23 that I bought a turbonetics kit for and Im throwing out the FIC, additional injectors, and MSD boost timing controller. I plan on boosting about 8-9 psi... I want to get the Hondata S300 but I don't know which ECU to get... P28 or P72... I want the EGR working and was wondering if the IABs can still be controlled under boost? Do I need bigger injectors? If so what size would be best for a max boost of 10 psi?
Old May 8, 2008 | 07:03 PM
98vtec's Avatar
moderator emeritus
Default Re: Concerning best ECU for Turbo application on my H23 (TheOdd001)
Kinda hard to determine what injector size you would need based on PSI. 10 psi could mean 250whp or 350+whp based on what turbo you used.
p72 can control IAB and has EGR functionality.
Old May 9, 2008 | 06:31 AM
TheOdd001's Avatar
Default Re: Concerning best ECU for Turbo application on my H23 (98vtec)
Well I'm looking to not go over 300whp and I have a T3/T04 A/R .63... So the p72 will allow for control of the IABs under boost?
Old May 9, 2008 | 09:36 AM
RA102725's Avatar
po6 would be fine i think... thats whati have and i planned on using.
Old May 9, 2008 | 10:01 AM
TheOdd001's Avatar
Default Re: Concerning best ECU for Turbo application on my H23 (mikesta21)
The Po6 doesn't control IABs though... right? Or does it matter when ur boosting?
Old May 9, 2008 | 10:58 AM
my9thtry's Avatar
I'm not sure why you think boosting your car has anything to do with a vacuum opperated solenoid.
If the ecu does not support IABs then it does not, if it does it does.
Thats not as hard as your making out is to be. If you want to keep all that junk then get a P72.
If it were me and i planned on keeping the H23 head, i would use the P74/75 teg LS ecu and delete the EGR and remove the IAB plate all together.
What are you tunning on?
Old May 9, 2008 | 09:52 PM
TheOdd001's Avatar
Default Re: Concerning best ECU for Turbo application on my H23 (my9thtry)
You mean what kind of dyno am I tunning on? I know IABs work on vacuum so I'm a little confused as to how the ecu controls them and I was wondering about power losses when boosted with no IABs...
Old May 9, 2008 | 09:56 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheOdd001 &raquo;</TD></TR><TR><TD CLASS="quote">You mean what kind of dyno am I tunning on? I know IABs work on vacuum so I'm a little confused as to how the ecu controls them and I was wondering about power losses when boosted with no IABs...</TD></TR></TABLE>
The IABS work on vacuum and electrical signal. There is a connector on the vacuum box.
Without IABs you will loose some tq at the lower end of the rpm band. It's all about what turbo setup you use and your tuning as to whether or not you need/want them.
I think he's asking what are you using to tune your boosted car?
Old May 10, 2008 | 01:53 AM
amalby's Avatar
Default Re: Concerning best ECU for Turbo application on my H23 (Hawkze_2.3)
What set you on S300? Im just wondering cause I am going to turbo my car and was going to use s300 like you are. Then I did some searching around and found Neptune RTP. It seamed to be the same and it is 200 dollars cheaper. They have great support and give free updates when they come out. its also incorporates blue tooth in the system so you can go wireless when tunning.
This is just something that I found. I am still not set on either one, but am leading toward the RTP.
Old May 10, 2008 | 10:33 AM
TheOdd001's Avatar
Default Re: Concerning best ECU for Turbo application on my H23 (amalby)
Well I'm going to a local shop to get it tuned on a dyno, they have tuned many vehicles with Hondata and are authorized by Hondata so I guess you could call them professionals... I chose the s300 because I like the fact that u can use a usb laptop to connect with it and I've been hearing of Hondata nearly all my life so naturally I looked at them. I saved up enough cash to do virtually what ever I want, I just want this done the right way and want my lude to be reliable!
So if I'm looking to keep it under 300Hp, am I gonna need bigger injectors and if so which ones should I get?
mikesta21 I had my pop ups disabled and never got your PMs till now... this darn trial membership doesn't let me do crap!
Modified by TheOdd001 at 11:40 AM 5/10/2008
Old May 10, 2008 | 10:56 AM
my9thtry's Avatar
Ah did see the S300 comment from your original post .
Yes get bigger injectors.
Like i said if your stuck on keeping both the EGR and IABs you must run a P72. Its just not what i would do.
Old May 10, 2008 | 02:49 PM
TheOdd001's Avatar
SWeeT! You guys rock, alot of things cleared up for me!
Old May 10, 2008 | 07:32 PM
TheOdd001's Avatar
Hey mikesta21 this trial account suckz but I bought a kit that came with everything includin IC and piping, Thanx though!
Stopsign32v
May 1, 2011 04:07 AM
mattsnooz
Engine Management and Tuning
May 15, 2008 11:21 AM
WiteSiprelude
Sep 28, 2005 07:00 PM
92SleeperH23
Feb 16, 2005 05:49 PM
GTRVspecII
Nov 28, 2002 06:10 PM
