water spots on the glass...
Old May 8, 2008 | 01:59 PM
kaotikvizion's Avatar
Default water spots on the glass...
just recently bought a 2000 ex 2 door and all the glass is stained with water spots. anyone know any way to remove?
Old May 8, 2008 | 02:01 PM
-Gambit-'s Avatar
Default Re: water spots on the glass... (kaotikvizion)
windex and elbow grease
Old May 8, 2008 | 02:16 PM
Ran4it2's Avatar
get some of that purple **** idk what its called
lol
but its really strong dont get it on your hands
windex wont take them off only acid based chemicals
Old May 8, 2008 | 02:19 PM
obuhmyuh's Avatar
Default Re: (Ran4it2)
or u could try using a clay bar and let it do all the work.
Old May 8, 2008 | 02:21 PM
Hoffy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaotikvizion &raquo;</TD></TR><TR><TD CLASS="quote">just recently bought a 2000 ex 2 door and all the glass is stained with water spots. anyone know any way to remove? </TD></TR></TABLE>
I have the same problem on one of my cars. I tried all types of window cleans and nothing takes it off.
Old May 8, 2008 | 02:22 PM
Default Re: (obuhmyuh)
these are somee hard core water spots I went to autozone & tried those discs you use with a drill to recondition you windshield & it did nothing. would the clay bar thing really work? & what kind of purple stuff or acid based chemicals are you talkin about?
Old May 8, 2008 | 02:25 PM
Speed_1's Avatar
i had the same problem i took a razor blade and some windex and it came off. Spray the window down with the windex and then hold the blade at a 45 degree and clean the window, No it wont scratch the window.
Old May 8, 2008 | 02:35 PM
Hoffy's Avatar
Default Re: (Speed_1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed_1 &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem i took a razor blade and some windex and it came off. Spray the window down with the windex and then hold the blade at a 45 degree and clean the window, No it wont scratch the window.</TD></TR></TABLE>
I tried both, but not at the same time. I will give that a try. Thanks!
Old May 8, 2008 | 05:08 PM
Crx Jimmy's Avatar
Default Re: (Hoffy)
try with some fine steel wool and some thinner
Old May 8, 2008 | 06:47 PM
Nixon161's Avatar
Default Re: (Crx Jimmy)
Got a pic of this ? I've never heard of water stains being that stubborn, they must be brutal.
Old May 8, 2008 | 06:52 PM
blwn95civic's Avatar
Default Re: (Nixon161)
simple green
and i think the purple stuff suggested is purple power... similar to simple green
Old May 8, 2008 | 06:53 PM
Hoffy's Avatar
I will try to take some tomorrow and post them.
Old May 8, 2008 | 09:26 PM
NOFX's Avatar
H-T White Ops
Don't use acid on the front windshield!
Btw, 0000 steel wool works too.
Old May 8, 2008 | 10:12 PM
ReactioN's Avatar
* B A N N E D *
Default Re: (NOFX)
How do you take old masking tape off a window?
Old May 8, 2008 | 10:14 PM
MotherFlower's Avatar
Default Re: (ReactioN)
VINEGER !!! Try it .
Old May 8, 2008 | 10:24 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReactioN &raquo;</TD></TR><TR><TD CLASS="quote">How do you take old masking tape off a window?</TD></TR></TABLE>
Flat razor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotherFlower &raquo;</TD></TR><TR><TD CLASS="quote">VINEGER !!! Try it .</TD></TR></TABLE>
I tried it and got nothing.
Out of the many different things I have tried, the steel wool was the most effective. It just takes a long time.
Old May 8, 2008 | 10:27 PM
VRD^don's Avatar
Default Re: (NOFX)
your automotive car wax..yeap the **** you used to wax your car..i've done it to mines. the window is sssoo cleeeaaaan and smooth afterwards. and no smudges or swirls or glears at all. give it a try and water beads up and rolls off and leaves no water marks.
Old May 8, 2008 | 10:38 PM
NOFX's Avatar
H-T White Ops
To give a heads up, they might not be water spots, but acid burns instead (from acid rain). Nothing in this thread worked on mine besides fine steel wool.
Old May 8, 2008 | 10:47 PM
ReactioN's Avatar
* B A N N E D *
Default Re: (NOFX)
Alright ill try!
Flat razor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">
Flat razor.
try that also!!
Old May 8, 2008 | 11:36 PM
NOFX's Avatar
H-T White Ops
Of course remember that a flat razor will remove or damage tint (in the event you're trying to remove it from the inside of the window on a tinted window).
Also be careful with the defroster lines.
Old May 13, 2008 | 11:44 PM
Default Re: (NOFX)
bump
Old May 13, 2008 | 11:59 PM
NOFX's Avatar
H-T White Ops
What more do you want?
Old May 14, 2008 | 09:42 AM
VRD^don's Avatar
Default Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">What more do you want?</TD></TR></TABLE>
post count..
Old May 14, 2008 | 11:54 AM
NOFX's Avatar
H-T White Ops
Default Re: (VRD^don)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRD^don &raquo;</TD></TR><TR><TD CLASS="quote">post count.. </TD></TR></TABLE>
Are you doing the same thing now?
Because I'm not.
Old May 14, 2008 | 12:48 PM
VRD^don's Avatar
Default Re: (NOFX)
Because I'm not. </TD></TR></TABLE>
yeap..been here longer then you have and you have more post count..trying to catch up..
