Strange bell type sounds when acceling in 5th
Old May 8, 2008 | 09:29 AM
Ser1N's Avatar
Default Strange bell type sounds when accelerating in 5th
Ok this is hard to explain,
I get this bell type ball bearing sound when I am accelerating in 5th gear (im sure it happens more but my car is too loud in other gears) Like if im going 60 in 5th and I push the gas a good amount. I can hear it.
Now i have heard this sound when i have almost stalled and have heard it on other cars that stalled.
It sounds like bells or metal ***** taping each other dunno how else to explain the sound. My timing belt is a little lose (dont know if that could cause any sounds like that)
I have searched but donno what key words i would check out to find it.
Modified by Ser1N at 10:36 AM 5/8/2008
Old May 9, 2008 | 09:09 AM
Ser1N's Avatar
Default Re: Strange bell type sounds when accelerating in 5th (Ser1N)
Old May 11, 2008 | 09:57 AM
Ser1N's Avatar
Old May 11, 2008 | 10:00 AM
jimmy o.'s Avatar
Do you have any idea where the sound is coming from can you hear it at idle?
Old May 11, 2008 | 10:13 AM
Civic_07's Avatar
how can u push 60 on 5th?...thats like bogging the engine dude...hhmm do u hear the sound when your accelerating or when u take ur foot off the throttle...i have the same sound but i only hear it when i take my foot off the throttle...except mine is louder in lower gears.
Old May 11, 2008 | 11:16 AM
obuhmyuh's Avatar
Default Re: (Civic_07)
timing belt is loose? is it possible it jumped teeth?
Old May 12, 2008 | 09:58 AM
Ser1N's Avatar
Timing belt is a little loose, but no way loose enough to jump teeth.
it does not make the sound at idle
I cruze on the freeway 60+ to what ever in 5th. I only hear it when im accelerating.
I have heard it in lower gears also tho, its not just 5th, its just easier to hear then.
I its just weird cause i have heard it on other civics when they stall, but not accelerating.
I may just ignore the sound tho it does not SEEM like its causing a problem but just odd. Ill just turn my radio up more maybe hehe. Just seeing if anyone else has noticed anything similar.
Old May 12, 2008 | 10:21 AM
ReactioN's Avatar
* B A N N E D *
Default Re: (Ser1N)
do you have a short shifter? i had that noise and it was my short shifter..
Old May 12, 2008 | 11:50 AM
randerson0248's Avatar
Pinging? Check ignition timing.
Old May 13, 2008 | 09:08 AM
Ser1N's Avatar
Default Re: (ReactioN)
Yes i have a short shifter (b&M) I think?? was the short shifter touching something?
its more of a bell sound not much of a pinging sound but i will check the timing anyway, i checked it about 5 months ago and it was fine but i will check again.
Turbo Powa
16
Jul 14, 2003 12:37 PM
jdmcivicferio
Mar 30, 2003 01:47 AM
Honda4CX-T
Nov 25, 2002 03:32 PM
