Engine Builders: Where to get a helper spring?
Old May 8, 2008 | 07:40 AM
AssPenny's Avatar
Default Engine Builders: Where to get a helper spring?
Due to the spec b's and milled head I have no idea how far I can advance my cams before I have contact. So I have to check some valve to piston clearences and I was going to use a helper spring instead of the stock valve springs. This will allow me to check the clearence at each degree with out have to remove the head a million times (using clay).
Thanks,
Craig
Old May 8, 2008 | 09:14 AM
AssPenny's Avatar
Default Re: Engine Builders: Where to get a helper spring? (AssPenny)
Sweet... http://store.summitracing.com/...758-2
Old May 8, 2008 | 12:56 PM
RStoR's Avatar
Craig - I just ordered Mike Belben's Degree Kit this morning and it comes with the mounting fixture, dial indicators, degree wheel, and a pr. of low tension springs. If you don't have everything yet, this is a great package.
Old May 8, 2008 | 01:30 PM
AssPenny's Avatar
Default Re: Engine Builders: Where to get a helper spring? (RStoR)
Where can I see/order the kit?
Old May 8, 2008 | 01:35 PM
PrinceAli132's Avatar
I believe his site was:
http://www.Newenglandhondarebuilders.com
But i think its down right now.
His username was something like mikebelben@yahoo.com
Ali
Old May 8, 2008 | 02:01 PM
AssPenny's Avatar
Default Re: Engine Builders: Where to get a helper spring? (PrinceAli132)
Thanks Ali. How is sunny FL? I am going to be down there for memorial day but I am debating working on the R or not. If I can get the damn thing tunable I might actually take it to expo
Old May 8, 2008 | 04:40 PM
B18CXr's Avatar
How much mill???
Old May 8, 2008 | 05:16 PM
TODAwhore's Avatar
Default Re: Engine Builders: Where to get a helper spring? (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">How much mill???
</TD></TR></TABLE>??
if you are deg. them in..then you wont have to worry about piston to valve clearence...i've done a few b18's with B's and C's that had about 20thou off the head and stock deck w/ a 2layer gasket that only took a little bit of advancing.
Old May 8, 2008 | 06:35 PM
D's Avatar
D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">How much mill???</TD></TR></TABLE>
IIRC .030+
Old May 8, 2008 | 08:17 PM
Aquafina's Avatar
Mikes site designer took off on him a while back and he can't change anything on it. He is very busy with a non-automotive job so he might not respond to you right away.
Old May 8, 2008 | 09:21 PM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RStoR &raquo;</TD></TR><TR><TD CLASS="quote">Craig - I just ordered Mike Belben's Degree Kit this morning and it comes with the mounting fixture, dial indicators, degree wheel, and a pr. of low tension springs. If you don't have everything yet, this is a great package. </TD></TR></TABLE>
godly
Old May 9, 2008 | 04:15 AM
RStoR's Avatar
Default Re: (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">Mikes site designer took off on him a while back and he can't change anything on it. He is very busy with a non-automotive job so he might not respond to you right away.</TD></TR></TABLE>
I got three emails from him yesterday and all were received within 45 mins of sending.
Old May 9, 2008 | 06:41 AM
totsie7944's Avatar
Hey man I've had toda B's and C's in there with CTR pistons and never had any clearance issues....I think you are ok.
Old May 9, 2008 | 07:11 AM
Aquafina's Avatar
Default Re: (RStoR)
I got three emails from him yesterday and all were received within 45 mins of sending. </TD></TR></TABLE>
Nice.
Old May 10, 2008 | 05:36 PM
I AM WEASEL's Avatar
Where did you order it from?
Old May 10, 2008 | 06:24 PM
RStoR's Avatar
Default Re: Engine Builders: Where to get a helper spring? (-DC4-)
Email Mike @ mike_belben@yahoo.com
He can give you all the details. My VTEC B-series kit w/degree wheel was $290 shipped. He offers several kits and the degree wheel is an option.
Bigjussin
Jan 24, 2016 05:56 PM
br8crumb
Jun 10, 2014 03:29 AM
HOMEMADEPOWER
Jan 31, 2011 04:07 PM
brandonschmidt
Dec 25, 2009 05:22 AM
smokey2.0
May 11, 2004 07:36 PM
