Mid-Atlantic (Sales) VA, DC, and MD
Fs: 84mm Ls/Vtec Complet swap and turbo kit+ Hondata. 433WHP
Old May 8, 2008 | 05:36 AM
7k rdlne's Avatar
Default Fs: 84mm Ls/Vtec Complet swap and turbo kit+ Hondata. 433WHP
Contact: Post or Pm
SOLD.. to a very happy customer!!!
Here are the specs:
00 Ls Bottom End
Golden Eagle sleeved 84mm
Endyn Pistons
Eagle Rods
Micropolished and balanced Crank
Toda Oil pump Gear
Moroso oil Pan
ARP Headstuds
B16 head
Combustion Chambers bored to 84mm to match bottom end
Crower Springs and retainers
Crower cam gears
B16 Cams
Edelbrock Intake manifold
Edelbrock 65mm Throttlebody
Aem Fuel Rail
RC 750 Injectors
Walbro 255Hp fuel pump
3 Bar Map
MSD distributor Cap and Rotor
MSD Coil
MSD Digital 6 Ignition
MSD Wires
Inlinepro SS T4 Manifold
Precision T4 T67 Turbo
3" downpipe and exhaust
Turbosmart wastegate
Inlinepro Dumptube
Inline Pro IC piping and couplers with T-bolt clamps
HKS style BOV
Turbo XS Dual Stage Boost controller
LS Trans
Compitition stage 5 Clutch- Brand New under 100 miles
Fidanza Flywheel
Evolution Industries Axles
Hasport Mounts
Stock Gsr shiftlinkage and dual bend shifter
Hondata S300
Autometer boost guage
Tuned By Brian Fisher at Inlinepro- 367whp on 11PSI 433Whp on 16PSI
The 750 Injectors are maxed out so thats the reason we stopped at 16PSI
Motor will Make 600+ with larger injectors and more boost, just dont have the money to dump on larger injectors at the moment
No problems with anything. Runs great. Like I said above if your serious I have no problem letting you test drive it while its in my car
Please keep negative comments to yourself
Price is $7000 OBO for everything listed above.
Modified by 7k rdlne at 12:27 PM 5/22/2008
Modified by 7k rdlne at 7:27 PM 6/1/2008
Old May 9, 2008 | 10:28 AM
7k rdlne's Avatar
Default Re: Fs: 84mm Ls/Vtec Complet swap and turbo kit+ Hondata. 433WHP (7k rdlne)
Old May 10, 2008 | 03:08 PM
7k rdlne's Avatar
ttt
Old May 13, 2008 | 04:13 PM
7k rdlne's Avatar
bump
Old May 14, 2008 | 12:02 PM
7k rdlne's Avatar
up
Old May 15, 2008 | 09:44 AM
7k rdlne's Avatar
ttt
Old May 16, 2008 | 01:30 PM
7k rdlne's Avatar
30 bump
Old May 18, 2008 | 02:00 PM
7k rdlne's Avatar
ttt
Old May 20, 2008 | 05:36 AM
7k rdlne's Avatar
bump
Old May 21, 2008 | 02:01 PM
7k rdlne's Avatar
ttt
Old May 22, 2008 | 08:28 AM
7k rdlne's Avatar
throw some offers
Old May 22, 2008 | 08:40 AM
TTE TEG's Avatar
Part the block?
Old May 22, 2008 | 04:48 PM
7k rdlne's Avatar
Default Re: (TTE TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TTE TEG &raquo;</TD></TR><TR><TD CLASS="quote">Part the block?</TD></TR></TABLE>
not really trying to part out but at this point throw an offer thats reasonable and I may
Old May 26, 2008 | 10:27 AM
7k rdlne's Avatar
ttt
Old May 29, 2008 | 10:43 AM
GotRiceYo's Avatar
PM sent
BUMP
Old May 29, 2008 | 01:48 PM
b18's_only's Avatar
Default Re: Fs: 84mm Ls/Vtec Complet swap and turbo kit+ Hondata. 433WHP (GotRiceYo)
r u going to sell the shell?
Old May 29, 2008 | 07:11 PM
7k rdlne's Avatar
Default Re: Fs: 84mm Ls/Vtec Complet swap and turbo kit+ Hondata. 433WHP (b18's_only)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GotRiceYo &raquo;</TD></TR><TR><TD CLASS="quote">PM sent
BUMP</TD></TR></TABLE>
replied
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18’s_only &raquo;</TD></TR><TR><TD CLASS="quote">r u going to sell the shell?</TD></TR></TABLE>
not sure yet... make an offer on it though
JDM97R
Jul 22, 2009 09:06 PM
7k rdlne
Jun 1, 2008 06:57 PM
7k rdlne
25
May 21, 2008 02:02 PM
7k rdlne
May 21, 2008 01:59 PM
7k rdlne
May 7, 2008 03:24 PM
