car wont accelerate
Old May 7, 2008 | 08:30 PM
HONDRETTI's Avatar
Default car wont accelerate
so i just finished dyno tuning my ls/vtec build tuned w/ crome, later replaced the iacv with a brand new one, car idles perfect.
took it out for a spin, hit vtec and bam! total loss of power. i try to accelerate from a dead stop and i bog/hesitate and the rpms rev freely, sometimes it catches but bogs again and sometimes stalls. its almost like something is clogged. NO CEL. i can let it idle and play with the throttle cable and the motor will surge/bog once i get to about 3k.
im stumped.
Old May 8, 2008 | 12:09 AM
Jimmy's Avatar
Global Moderator
Sounds like your in limp mode..
Are you sure your not throwing and codes.. Is the check engine light bulb there?
Old May 8, 2008 | 06:08 AM
HONDRETTI's Avatar
Default Re: (Jimmy)
yea ive had a cel before...
Old May 8, 2008 | 06:48 AM
kaspa35's Avatar
Default Re: (HONDRETTI)
that sounds similar to a problem i had a few days ago...i was just bogging down...and it would just die and the check engine light would come on..im not sure if yours does...but i would say check your spark plugs....thats what my problem was...hopefully its all thats wrong with yours....
Old May 8, 2008 | 09:13 AM
HONDRETTI's Avatar
Default Re: (kaspa35)
i just changed the plugs
Old May 8, 2008 | 12:52 PM
HONDRETTI's Avatar
Default Re: car wont accelerate (HONDRETTI)
i figured out what it is... i took my tps off and the spring loaded arm fell out... broken tps.
jhpusa.com has them on sale for 25 dollars plus free shipping. giddy-up!
chadleehonda
Jun 30, 2010 07:35 PM
pimpwagon
May 8, 2008 03:32 PM
grjp1988
Feb 18, 2008 12:13 AM
champwhiteitr
Mar 17, 2004 03:39 PM
