Can I use this crankshaft pulley on a 91 Civic DX?
Can I use this OEM Honda crankshaft pulley on a 91 Civic DX hatch with no power steering? It's a little different than the one I removed (now broken) and a little heavier due to the top part shown on this picture - used for power steering. Will the added weight cause significant change in performance?
Modified by braass91 at 9:39 PM 5/7/2008
ok, so the crank pulley u got now is heavier than the one u had b4, if u put it on now its gonna make a difference cause its heavier, if im not wrong u have 2 rebalance the crankshaft due to having more weight on the timing belt side, if u take a CTR N1 crank pulley and slap it on a GSR or LS its gonna hurt it cause the crankshaft is not balanced for the CTR crank pulley weight which is 1.8 lbs, so less the weight rpm goes up faster but hurts the crankshaft, n/e thing else u need 2 know????
zrs6v4
Feb 16, 2016 11:57 AM
Neptronix
Dec 28, 2007 08:11 PM
Tyson
35
Dec 30, 2004 03:06 PM
Death_to_Thieves
Feb 19, 2004 01:45 PM
