This is driving me nuts!! Help please!!
Old May 7, 2008 | 07:58 PM
k20tuRbo's Avatar
Default This is driving me nuts!! Help please!!
Ok this is seriously driving me nuts..... My problem started last week I put race gas in uploaded my race gas map and went for a drive lean cut was off so I am watchig my a/fs just to make sure everything was good I started going really lean lilke 15 16 17:1 so I let off thinking my plugs were bad. I gap a new set and throw them in same problem. So I start adding fuel to my boost columns I mean alot of fuel same problem. Now I am at the point I have a fuel system problem so I check my pick up it checks out ok. Next I check the filter checks out ok. Next I try a new fuel pump same problem. Next a new set of injectors same problem. Next tested the fpr same problem. So now I move on to well maybe the gas is bad so I drain 10 gallons of race gas out of my car put pump gas back in load my pump gas map same problem. So now I am thinking 02 sensor so I try a new one same problem. So now I move on to the ecu....guess what same problem! I am now running on my pump gas map with fuel values way higher than they should be and still the same problem. I have redone my map and I am using the newest version of kmanager... Anyone have any ideas? Also my injector milliseconds is very high is that a bad thing?
Just to recap everything was running fine until I uploaded my race gas map and put race gas in.
I am using hondata kpro and a bosch inline pump, this is on a k20a2
ant94eh3
Sep 24, 2011 04:15 PM
eh2Ry
Aug 6, 2008 07:10 AM
MK Ultra
Sep 10, 2003 12:38 AM
chiefvtec
Mar 28, 2003 11:40 AM
