OIL LIGHT. normal or no
Old May 7, 2008 | 07:50 PM
teggy_617's Avatar
Default OIL LIGHT. normal or no
u know how when you turn your car on. the engine light and oil light pop up and dissapear right away.. well my oil light stay on for like 10 secondd and it turn off. IS THAT NORMAL? or there somethanggg wrong. and does it affect vtec?
becauseee
sometime after i hit vtec i feel like my car is loosing a lil power. like when i slam the gas pedal my car doesnt seem fast...(that after i hitt vtec)AND THIS SOMETIME HAPPEN only. like every other day. and soemtime vtec just work normalllyy.. . please give me some advice.. thank you.
Old May 7, 2008 | 07:55 PM
SkaiWu's Avatar
if oil light comes on when you hit vtec it means you need oil...
Old May 7, 2008 | 08:20 PM
teggy_617's Avatar
Default Re: (SkaiWu)
the light stay on for 10 sec when i turn the engine on .and it turnn off. it only happen when i turn the car on.
Old May 7, 2008 | 09:18 PM
vsmdc4teg's Avatar
Go be smart and safe and check your oil level before driving again.
Old May 7, 2008 | 09:49 PM
khaltire's Avatar
I remember seeing something about this in the manual, but I dont remember what
Did oyu think of checking it?
I remember it says it should stay on for a few seconds then dissapear. If its on for 10 sec or more (or something like that) or on constantly, you need to do whatever it says in the manual. I think it said stop driving immediately
Old May 7, 2008 | 11:54 PM
Jimmy's Avatar
Global Moderator
Could be a failing oil pressure switch.
Check engine oil, if oil is fine.. You need to check your oil pressure.
Old May 8, 2008 | 04:35 AM
teggy_617's Avatar
Default Re: (Jimmy)
eventhough after i change my oil. it still stay on for like 5 sec maybe not 10 but at least 5. this happen only when i turn the car on. it stay on for 5 sec than dissapearr. NOT WHILE IM DRIVING.
Old May 8, 2008 | 08:08 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (teggy_617)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsmdc4teg &raquo;</TD></TR><TR><TD CLASS="quote">check your oil level before driving again. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khaltire &raquo;</TD></TR><TR><TD CLASS="quote">Did oyu think of checking it?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Check engine oil</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggy_617 &raquo;</TD></TR><TR><TD CLASS="quote">(irrelevant response deleted)</TD></TR></TABLE>
Message to the clueless:
<FONT SIZE="4">USE THE DIPSTICK TO CHECK YOUR OIL LEVEL.</FONT>
Old May 8, 2008 | 01:43 PM
Steven.'s Avatar
if only when u turn it on i dont see reason to worry lol
Old May 9, 2008 | 09:05 AM
GSR-TRBO-DA's Avatar
Default Re: OIL LIGHT. normal or no (teggy_617)
what weight oil are you using that could be the reason it takes so long for the light to come off. because it takes too long for the pump to build up pressure because the oil is to thick, it should be 5/20.
Old May 10, 2008 | 11:47 AM
vladd's Avatar
Default Re: OIL LIGHT. normal or no (GSR-TRBO-DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-TRBO-DA &raquo;</TD></TR><TR><TD CLASS="quote">what weight oil are you using that could be the reason it takes so long for the light to come off. because it takes too long for the pump to build up pressure because the oil is to thick, it should be 5/20.</TD></TR></TABLE>
honda recommends 5w30. and yes, check the oil level.
Old May 10, 2008 | 12:31 PM
lmike6453's Avatar
another troubleshooting tip is turn ignition to number 2, where you're heat and a/c works, and power windows wokr without car running, and see if the red oil light stays solid...
or if it does the same thing
Pr-Type-R
Apr 20, 2008 05:09 PM
dis
Mar 16, 2006 08:38 PM
lilxvtecxpwr
Sep 4, 2003 10:51 PM
Sohc Driver
Jul 9, 2003 11:38 AM
jond
Mar 30, 2003 12:09 PM
