Great Oil Catch Can Mounting Spot...
Old Jul 14, 2002 | 01:25 AM
Tommy_Gunns's Avatar
Default Great Oil Catch Can Mounting Spot...
Here's a pic of my mounting spot for my oil catch can. Notice how the lowest point of the hoses is the red PCV nipple, this is important so you do not accumulate oil in the line (especially if you are not running clear hoses). I traced the lines, GREEN for oil catch can outlet and VIOLET for oil catch can inlet.
Full sized version below, copy and paste in new browser window.
http://www.imagestation.com/picture/...9.jpg.orig.jpg
[Modified by Tommy_Gunns, 4:27 AM 7/14/2002]
Old Jul 14, 2002 | 01:35 AM
Default Re: Great Oil Catch Can Mounting Spot... (Tommy_Gunns)
Dang, I wish I could change the title of the post.
I would change it to, "Proper way to mount an oil catch can."
Old Jul 14, 2002 | 01:41 AM
JDMITR222's Avatar
good job that'll help me mount mine when i get one.
Old Jul 14, 2002 | 07:20 AM
Warren's Avatar
Wrong-Way Wang
I always forget which way this engine torques under accel and braking. Does that can get smacked?
Warren
Old Jul 14, 2002 | 07:23 AM
Toda Party's Avatar
Default Re: Great Oil Catch Can Mounting Spot... (Warren)
under acceleration it will lean backwards towards the can, yeah...
Old Jul 14, 2002 | 07:40 AM
DarthLuder's Avatar
New User
Tommy_Gunns what type of oil catch can it that. I mean brand of oil catch can.
Does anyone know will thle Greddy oil catch can fit in the Integra?
Old Jul 14, 2002 | 08:31 AM
SurferX's Avatar
Thank you so much for posting this. I have wanted to get an oil catch can for awhile now but could not figure how to mount it. What kind of can is that and did you mount it using stock bolts or did you do some drilling?
Old Jul 14, 2002 | 09:19 AM
Dr Pooface's Avatar
Why is your strut tower bar all scratched up?
Old Jul 14, 2002 | 11:07 AM
Reid's Avatar
Global Moderator
Default Re: Great Oil Catch Can Mounting Spot... (ITR GURU)
That's a Cusco.
I'm sure in the process of installing parts/regular car maintenance accidents are sure to happen.
Old Jul 14, 2002 | 01:43 PM
There is about an inch of clearance between the catch can and the intake manifold. Even if it does hit, there is some give at the top of the can as it is not right against the firewall (about an inch away).
I have not had any problems so far with it mounted there (no rattling, no smacking, no looseness).
I bent some brackets in order to mount them using stock bolts already on the firewall. It is bolted down by the brake master cylinder bolt and to the brake line distribution block (or whatever it is called). It is a Cusco oil catch can.
Old Jul 14, 2002 | 01:45 PM
Default Re: Great Oil Catch Can Mounting Spot... (Ddub)
The answer to this is the same as the answer to "why is my engine bay so dirty?"...I don't know and I don't give a fug
I bought my car used so beats me why it's all scratched up. Those are hair line scratches that show up on the digi cam, the scratches are not noticeable with the naked eye.
Old Jul 14, 2002 | 01:52 PM
Oh one more thing...
I used to have clear nylon braided hoses but they collapsed from the under hood temps. I have since switched to fuel line (black hose) and some hard clear plastic hose that I found at Home Depot. The reason why I didn't put the clear stuff all the way around is because it is difficult to bend.
My current setup has been through 2 autocross events and there is no signs of collapsing or anything.
I will try to get my hands on some play doh and clay the catch can to see if the intake manifold is hitting it or not.
Old Jul 14, 2002 | 05:04 PM
Tweakmeister's Avatar
fuel line is
that spot is
Old Jul 14, 2002 | 05:28 PM
1GreyTeg's Avatar
Default Re: Great Oil Catch Can Mounting Spot... (SurferX)
Yes, this WAS a very good posting, Especially the PICS "with cool colored arrows!"
Thanks,
A.
Old Jul 14, 2002 | 05:37 PM
ITR21's Avatar
Default Re: Great Oil Catch Can Mounting Spot... (1GreyTeg)
which oil catch can is that?
Old Jul 14, 2002 | 05:39 PM
RagingAngel's Avatar
Default Re: Great Oil Catch Can Mounting Spot... (ITR21)
Old style Cusco.
New style has metal fittings.
Old Jul 14, 2002 | 07:45 PM
PSU's Avatar
PSU
formerly DxHatchback
nice post
Old Jul 15, 2002 | 12:03 AM
EagleR's Avatar
Default Re: Great Oil Catch Can Mounting Spot... (DxHatchback)
looks good....
Old Jul 30, 2002 | 09:59 PM
SloEG's Avatar
Sorry, but I thought catchcan were used to replace the valve cover hose that runs into the intake piping? Can anyone explain why it was used for the intake manifold only?
I figured it'd be good to run one for the valve cover since at high rpm, it blows oil vapors (& hot air). In the future, it could leave some buildup in throttle body and intake manifold.
An MR-2 guy told me that its better to run the hose from the valve cover to the intake piping to maintain valve pressure? Not sure if this true.....can anyone share some light to this?
Old Jul 30, 2002 | 10:41 PM
Default Re: Great Oil Catch Can Mounting Spot... (SloEG)
more like the crankcase needs to be vented to prevent excessive pressure from the motor pumping...
those people who cap off the valvecover remains a mystery to me.....
Many race motors still vent the valvecover...most high RPM Hondas ....ie. JUN crate motor sport dual vents above the header (valve cover drilled and tapped for earl's fittings) and they dump into a can....
Old Jul 30, 2002 | 11:10 PM
Kengs's Avatar
Default Re: Great Oil Catch Can Mounting Spot... (RagingAngel)
Nice job
Old Jul 30, 2002 | 11:15 PM
Mario's Avatar
The Greddy can is universal, and it's heavy!
I used to have clear nylon braided hoses but they collapsed from the under hood temps...
Yeah, mine is starting to do that too. Better make a visit to Earl's soon, heh.
Old Jul 30, 2002 | 11:25 PM
SloEG's Avatar
Oh, I'm running a breather on the valve cover. I have not seen one person yet plug up the valve cover hole. I'm still wondering why someone would use the catchcan on the intake manifold body and the intake manifold runners. Anyone?
Old Jul 31, 2002 | 06:45 AM
BSQ's Avatar
BSQ
See the diagram below (from the Helms manual) of the PVC system. You will see that BLOW-BY VAPORS exit through the BREATHER CHAMBER --> PCV VALVE --> PCV HOSE and back into the intake manifold. Oil droplets are contained in the BLOW-BY VAPORS; therefore, you need to install the oil catch can between the PCV valve and the intake manifold.
You do not want to install the oil catch can between the valve cover and the intake tube, because this supplies FRESH AIR to the crankcase.
Old Jul 31, 2002 | 10:06 AM
SloEG's Avatar
Default Re: Great Oil Catch Can Mounting Spot... (BSQ)
So I should connect the hose back from the valve cover to the intake piping?? Or does it not matter? I thought it would be a good idea to this since I've seen old civic intake hose and theres a thin layer of oil on the inside of the piping hose and throttle body.
