BOV flutters, do i loosen or tighten?
Old Jul 14, 2002 | 12:53 AM
ceemarun's Avatar
Default BOV flutters, do i loosen or tighten?
its weird typing this, but it sorta sounds like "psh..psh..psh..psh"....when i blow off (HKS SSQ). should i loosen or tighten the BOV? and when i do adjust it, do i do it at idle, or w/ the car off, and when should i stop? thanks for all the help.
Old Jul 14, 2002 | 01:24 AM
turbocoupe's Avatar
Default Re: BOV flutters, do i loosen or tighten? (ceemarun)
HKS SSQ is suppost to sound like that. You're in the clear.
Happy boosting.
Old Jul 14, 2002 | 08:31 AM
SiRkid's Avatar
doesnt matter when you adjust it ..just make sure your not driving
its only supposed to sound like that occationally! say partial boost and throttle.. full out driving.or full boost etc...it should be a loud chirp! i would tighten it alittle bit!
Old Jul 14, 2002 | 10:49 AM
ceemarun's Avatar
Default Re: BOV flutters, do i loosen or tighten? (SiRkid)
im only boosting a max of 3psi right now and never WOT cuz im running on a base map for now. still normal right? thanks for the help!
Old Jul 14, 2002 | 05:37 PM
Flamenco-T's Avatar
change you vacuum source....
try to have a single source of vaccum...
it'll work..trust me
Old Jul 14, 2002 | 05:50 PM
ceemarun's Avatar
Default Re: BOV flutters, do i loosen or tighten? (Flamenco-NA)
this is coming off the fpr. only this and the boost gauge feeds off the fpr. thats too much off one source already?
Old Jul 14, 2002 | 05:55 PM
Flamenco-T's Avatar
hmm, you might want to tap it off from the EVAP purge valve or other sources...
I only tap 2 vac lines per source....just me though...
Jayboy
May 12, 2005 10:57 PM
VI Boost
Dec 11, 2004 06:59 PM
XxRoCkMaNxNEOxX
Nov 5, 2004 07:30 PM
Trac226
May 25, 2002 07:20 AM
Doodoo
Oct 8, 2001 10:11 AM
