GSR Swap
Old May 7, 2008 | 01:00 PM
Abius's Avatar
Default GSR Swap
Hi all,
Im planning on swaping a OBD1 GSR into my 93' Civic HB DX. I was just wondering on a couple things that I would need.
And as for a place to egt it from, would it be better to go local so I can take a look at the engine before they send it to me.
The swap comes with the following parts:
Complete Block Head
5 speed Transmission
jdm ECU (P72)
jdm Wiring harness OBD1
Distributor
Exhaust Manifold
Down pipe
Intake Manifold
Fuel Rail
Injectors
Sensors
Starter
Half Shaft/Intermediate Shaft
Alternator
A/C Compressor
Power Steering Pump
Throttle Body
Shifter Linkage and Axles
stock motor mounts
+LSD if they have it
Since the swap comes with jdm Wiring harness OBD1 do I need to buy a harness from rywire ( http://rywire.com/store/9295-c...1e6d6 )
Other then that are there other things that I need?
Im going to be replacing the radiator and fan. ANything else?
Thanks.
Old May 7, 2008 | 02:10 PM
chimmike's Avatar
Default Re: GSR Swap (Abius)
check the FAQ's
Old May 7, 2008 | 02:31 PM
Abius's Avatar
Default Re: GSR Swap (chimmike)
I have read over some of the FAQ
rev210k
Northeast (Sales)
11
Nov 26, 2010 10:03 AM
206 EH2
Aug 20, 2008 01:11 PM
Abius
21
May 27, 2008 04:38 PM
likenother
Mar 18, 2006 08:35 PM
