click sound when releasing throttle
Old Jul 13, 2002 | 11:43 PM
GSR -97's Avatar
New User
Default click sound when releasing throttle
Hi,
I'm hearing a click sound when I release the throttle...only when moving.
Just started recently I think. I'll accelerate but when I release the gas pedal I hear a click...comming from the right ((passenger side) of the engine.
It's not super loud...just wondering if anyone knows what it could be before I go to the mechanics.
Thanks
Old Jul 14, 2002 | 09:50 AM
oc3's Avatar
oc3
New User
Default Re: click sound when releasing throttle (GSR -97)
I recently started experiencing this as well, except maybe its more of a "clunk" than a "click". Only happens when I let off the gas in a low gear. I thought it was the lower ball joint because the boot was ripped so I replace it, but it didnt go away. My axles are only two months old (driveshaft shop stage 1) so I don't think its the CV joint. Also the upper ball joints are only about six months old (part of the Skunk 2 camber kit). I'm not sure what to look at next.
Old Jul 14, 2002 | 10:12 AM
Chiovnidca's Avatar
Did you check your motor mounts?
Old Jul 14, 2002 | 02:38 PM
Quick 200k Mile Motor's Avatar
Default Re: click sound when releasing throttle (Chiovnidca)
throttle plate
Old Jul 14, 2002 | 06:26 PM
Kamin's Avatar
Default Re: click sound when releasing throttle (oc3)
does it do it at idle?
if it does its just the butterfly in the torottle body closing. or the return spring working the way it should. dont worry.
diva_3181377
Sep 14, 2018 08:27 AM
IntegraR0064
Aug 9, 2017 06:11 PM
beginmyhonda
Jan 12, 2009 11:33 AM
ImThaBean
Jul 13, 2008 12:36 PM
Lo-Buck EF
12
Nov 26, 2002 07:29 PM
