What kinda washers/o-rings do you use for your AN fittings on the fuel rail?
hey guys just wondering what kinda washers/o-rings are you supposed to use for the an fittings that attach to the fuel rail? Does it have to be a metal washer or can it be a Nitrile o-ring?
thanks!
thanks!
you can get a whole assortment of rubber o-rings at harbor freight. then just pick the size that slips over the an fitting snug
Use something along the lines of a Viton O-Ring.
Aeromotive has what you need available in a variety of sizes.
They make a variety of seals for AN o-ring port adapters. They make buna-n, viton, stat-o-seals, aluminum crush washers. All are acceptable.
I've used an oil drain plug crush washer (M14) for a -6AN o-ring port on the fuel rail once.
mrbsponge
Mar 9, 2005 04:41 AM
