need new rings....
Old Jul 13, 2002 | 09:19 PM
B18C-RnVA's Avatar
New User
Default need new rings....
im getting major blow by here and iv figured it out to be the piston rings...well anyways...
do i have to get the block rehoned if im just replacing the rings on the pistons. Using same pistons just want to put new rings on them.
Old Jul 14, 2002 | 01:34 AM
MikeSarr_GSR's Avatar
Default Re: need new rings.... (B18C-RnVA)
pull the head
drop the pan, the windage tray and girdle
remove the pistons and rods
cover the bare crank
refresh the rods with new rod bearings
hone the cylinder walls, not rebore with a honing tool
to make sure the ridge at the top of the cylinder lining
is clean
if your goal is to go boost, then research your options
on a head gasket and block stiffening while it is apart
for more rigidity and strength, install ARP rodbolts
install oil temp, pressure gague kit an oil cooler and
competition ITR oil pump I know Endyn makes one
for 200 bucks.
also, change the rings.
you will be in much better condition when you do
this than just changing the rings and this can be
had for under a grand.
Old Jul 14, 2002 | 04:34 AM
IN VTEC's Avatar
You might as well disassemble the head while you're at it and replace the valve seals.
It would also be the time to install valvetrain components if you had any planned.
nick91civicsi
Nov 11, 2006 11:06 AM
sodacan33
Jun 10, 2004 07:10 AM
ludelvr
Apr 6, 2004 04:41 PM
Holden
Feb 21, 2003 03:56 PM
Westrock2000
Mar 30, 2002 04:31 PM
