Bad misfiring in dual carb ZC
Old May 6, 2008 | 03:28 PM
_deagle_'s Avatar
Default Bad misfiring in dual carb ZC
Hi guys..
Getting bad misfiring from a dual carb ZC motor.. Have swapped spark plugs and cleaned out dizzy..
Suggestions guys?
Thanks
Old May 6, 2008 | 04:42 PM
Blahblah718293's Avatar
Default Re: Bad misfiring in dual carb ZC (_deagle_)
i: like im sure most of the other people around here dont know much about carbed vehicles, im going to school for automotive technology right now and carbs arnt even in the curriculum. sorry bud.
Old May 7, 2008 | 03:25 AM
Dogginator's Avatar
Daisy... Daisy...
What do the spark plugs look like?
Old May 7, 2008 | 07:18 AM
steveharrmr23's Avatar
Default Re: Bad misfiring in dual carb ZC (Dogginator)
i know a good deal about carbs considering i grew up helpin my grandfather maintain the vehicles
Old May 23, 2008 | 04:03 AM
_deagle_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">What do the spark plugs look like?</TD></TR></TABLE>
Really carboned up.. Have removed the spark plugs and cleaned them, it started up but mis-fired and cut out. Took plugs out again and they were fully carboned up again
Old May 23, 2008 | 04:15 AM
Dogginator's Avatar
Daisy... Daisy...
You could either be running rich, have retarded timing, or a weak spark. I would guess running rich. Is there a choke on those carburetors?
Old May 23, 2008 | 05:51 AM
JETSPD1477's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">You could either be running rich, have retarded timing, or a weak spark. I would guess running rich. Is there a choke on those carburetors?</TD></TR></TABLE>
what dogg said... make sure the choke isn't sticking... play around with the mixture screw... start on the lean side of things and tune from there. makes sure you dont tighten the screw too much or you'll ruin the needle.
Andycuso
Nov 18, 2012 08:50 PM
mrvrsick
Jul 5, 2008 01:06 PM
CWBETB
Nov 27, 2005 08:14 AM
ekblacknight
Jul 28, 2004 07:58 PM
Red D Dragon
Sep 6, 2003 08:49 PM
