89 CIVIC wheel alignment!!!
Old May 6, 2008 | 11:17 AM
briver2006's Avatar
Default 89 CIVIC wheel alignment!!!
I am ignorant when it comes to my honda. My front tires are wearing out in the inside, i took to wheel alignment shop and they said that there was no more adjustment. what suspension parts do I need to replace on the front end to get those tires flat, and tighten up my suspension? it drives pretty good except when it is windy.
thanks,
B
Old May 6, 2008 | 11:33 AM
D50boy's Avatar
Default Re: 89 CIVIC wheel alignment!!! (briver2006)
If it has a 20 year old suspension, it may be time for new springs. Has anything been done to the car at all?
Old May 6, 2008 | 05:19 PM
Tyson's Avatar
how can there be "no more adjustment"?
theres PLENTY of adjustment in the fronts.
if theres not, then your car is way out of whack. probably bent arms but itd be noticable if there was no more adjustment left.
take it to another competent shop.
Old May 6, 2008 | 06:42 PM
jdm_ef9_b16's Avatar
the only factory adjustments you have, are rear toe, and front toe
rear camber can be adjusted by shims, front camber can be adjusted with aftermarket adj. ball joints or adj upper arms.
when you have no more adjustment, you have worn parts or something is bent.
in the front you only really have toe adjustment from the factory
caster may be adjusted possibly like accords with shims in your strut rods. the arms going from your lower control arm to your front crossmember, camber is not adjustable from the factory.
hope that helps.
Old May 6, 2008 | 07:11 PM
viciousef9's Avatar
i would start by gettin new tires and then alignment. maybe a camber kit
Old May 7, 2008 | 08:28 AM
welfarepc's Avatar
if u are going to get a camber kit get the skunk2 style, and dont get the ebay version.
unless you like ball joints popping out and snapping
pKjai
Suspension & Brakes
Oct 27, 2010 08:28 PM
bb_one
Suspension & Brakes
Apr 18, 2009 04:02 PM
Historyg
Dec 22, 2007 05:42 PM
rungel
Nov 28, 2007 05:34 PM
TEG98
Apr 6, 2003 08:33 AM
