Y21 Gearbox Problem
Old May 6, 2008 | 10:26 AM
vtec6200's Avatar
Default Y21 Gearbox Problem
I have just bought a vti civic and a problem has surfaced that I didnt notice when purchasing. Its making alot of noise when reversing I mean alot!! it sounds very rough. Anyone have any ideas what could be causing it?
Old May 7, 2008 | 11:41 AM
vtec6200's Avatar
Default Re: Y21 Gearbox Problem (vtec6200)
With all the people on this forum can nobody give a guess as to what is the problem.
Old May 12, 2008 | 03:12 AM
vtec6200's Avatar
Bump
Old May 12, 2008 | 03:17 AM
RIZOBIZERT's Avatar
When you say sounds 'rough' can you describe the sound further? The situation sounds like you may have to pull the trans. and inspect the gears making sure the change forks are engaging properly.
Old May 14, 2008 | 02:24 AM
vtec6200's Avatar
Like a loud grinding and whining noise
Old May 14, 2008 | 03:15 AM
RIZOBIZERT's Avatar
Default Re: (vtec6200)
Well, whining noise? Is it similar to the reverse noise that a transmission usually has? Transmissions whine in reverse because the gear is straight cut. As for the grind......hmmm.....you've got me stumped.....anyone else have thoughts on this without opening the trans.?
Old May 14, 2008 | 06:26 PM
redhatch8u-up's Avatar
does it grind going into reverse and then whine? depending on when you are trying ot engage reverse like under a load or not fully stopping could cause it to grind a little going into gear and the whining is normal all Hondas do it much like if you hear one start up they all sound the same
Old May 14, 2008 | 06:32 PM
elektronsi's Avatar
Default Re: (redhatch8u-up)
are you fully engaged in reverse, sometimes hondas need a little encouragement to get into reverse, atleast the ones that ive owned, and if they arent fully in reverse they will make a grinding noise
Old May 16, 2008 | 03:15 PM
vtec6200's Avatar
Its defently fully engaged. the faster you go back the louder the grinding noise and also the whining which is like the reverse whin but alot louder
chefcook
Nov 2, 2016 02:06 PM
slowpokecivic
Sep 30, 2005 01:59 AM
Crucial_CiviC
Aug 21, 2005 09:19 PM
H.crx-si
Aug 5, 2004 01:03 PM
