noob engine swap question
Old May 6, 2008 | 05:10 AM
ten2doyle102's Avatar
Default noob engine swap question
Hi,
I recently bought a 1995 civic lx. Its got the standard d15b7 in it already and had an auto to manual tranny swap done to it too with an EX transmission. I am going to swap in a newer motor cause something must have happened while i was driving it back up since it is now currently burning about a 1/2 quart of oil in about a week.
Anyway, i was wondering if a ex motor from a 96-00 civic would bolt up to the ex transmission and if it will just drop right in with the stock mounting locations, they are both d-series motor but i just want to make sure before i go and buy it. also, i don't know if anyone else has done this, but the motor would come with everything (wiring harness, axles, auto trans and ecu.) I dont think that i should need new engine mounts though so i am not worried about that.
Old May 6, 2008 | 05:14 AM
Jakester9500's Avatar
Default Re: noob engine swap question (ten2doyle102)
well, you'll have to swap some stuff around on the automatic engine. such as your flywheel, along with flywheel bolts.
but why buy a full swap when you don't need most of it? just keep an eye out for a longblock.
Old May 6, 2008 | 07:21 AM
Default Re: noob engine swap question (Jakester9500)
well i was planning on seeing if i can get the guy to sell me just the motor, ecu and wiring harness. I just want to make sure that transmission i have will bolt up. I did forget to mention that its a 95 ex tranny, dont know if that matters.
Old May 6, 2008 | 08:06 AM
CivicSpoon's Avatar
Transmission bolts right up. If you're going to use the ECU, you're going to need a conversion harness (OBD1 to OBD2[A or B]), because it has different plugs than what your car comes with.
Old May 6, 2008 | 08:37 AM
if your car is manual, which it sound like it had the conversion done, then the automatic ecu is also a waste of money
Old May 6, 2008 | 08:59 PM
Default Re: (Jakester9500)
thanks guys! i'll let you know what i decide to get cause i might be getting a d16z6 from a fellow honda guy on here.
b15
Dec 30, 2009 02:51 AM
LongSol86
Oct 24, 2006 05:40 AM
mrpeabody
Sep 29, 2004 12:06 PM
tltas0325
Apr 13, 2004 08:21 PM
kingpen
Sep 1, 2002 12:16 PM
