Hatchback Rear Quarter Glass---SEARCHED
Old May 5, 2008 | 09:53 PM
SPOONfed-Rex's Avatar
Default Hatchback Rear Quarter Glass---SEARCHED
The car is a 91 Civic Si... The problem is there is a small rattle that comes from both quarter glass windows...this is anytime I hit a small bump and just going over bumpy roads....had anyone had this problem and solved it...is there anyway to tighten the lever that opens and closes the window...the tab outside must hide a screw but at the same time am afraid it doesnt and I will break the tab for no reason...Any help will be appreciated...
Old May 6, 2008 | 05:19 PM
Default Re: Hatchback Rear Quarter Glass---SEARCHED (SPOONfed-Rex)
anyone
Old May 6, 2008 | 05:39 PM
1kleenef's Avatar
ur problem lies in the hatch area all u need to do is open ur hatch and unscrew the little black tips underneath the hatch and it should solve the problem just unscrew them enough to provide even pressure on the hatch
Old May 6, 2008 | 07:19 PM
I am talking about the passanger side glass..the ones that open slightly...they seem to rattle...where do i tighten them or adjust them?
Old May 6, 2008 | 08:58 PM
problem_si's Avatar
You answered your own question. There are 2 screws under that cover. Reset them so that there is adequate pressure on the window when its closed. Also check the other mounting points to make sure everything is tight.
FormulaTeg
Nov 11, 2022 06:09 PM
Braco11
14
Feb 23, 2007 01:39 PM
OnePointFive
Jun 18, 2004 11:08 PM
OmegaLS
Sep 21, 2003 09:34 PM
InfamousRS
Jul 2, 2001 12:39 PM
