Apexi VAFCII in a 01 gsr
wsup HT! so i got a apexi vafc 2 in my gsr and i wanna take it out but i was wonderin if i take it would the settings still be the same or will the settings default and go back to stock?! thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keepinitrehaal »</TD></TR><TR><TD CLASS="quote">wsup HT! so i got a apexi vafc 2 in my gsr and i wanna take it out but i was wonderin if i take it would the settings still be the same or will the settings default and go back to stock?! thanks in advance.</TD></TR></TABLE>
If you disconnect the harness or undo the VAFC it will initialize it's self (reset)
If you undo it and want to plug it back in..
You will need to do the following:
- Set the sensor type to 6 in 6 out
- Set the Cylinders to 4 cylinder
- Set the throttle position to the top right.
Then you will be running all stock fuel settings,etc.
