VALVES VALVES
HEY PEPS
I JUST PURCHASED THIS PRO SERIES ,CAM GEARS,CAMSHAFT ,SPRING &REATAINERS
BUT IM STILL LOKING FOR THE VALVES IM NO'T 100% SURE ABOUT GETTING THE COMPLETE SKUNK2 VALVETRAIN
I NEED HEADS UP
I'LL BE BOOSTING A STOCK GSR MOTOR WHILE I RESLEEVE MY SECOND GSR BLOCK SQUEZING A T3/T61 MAX 500HP,BUT FIRST I'LL BE CHANGING ALL MY HEAD SEALS
WHAT DO YOU RECOMEND
I NEED HEADS UP
I just did the same thing and im happy with it all I can get those skunk2 valves for 235 shipped lemee know. I also can get UGR valves skunk2 sister company for 185. Basicaly the same valve but a differnt name. Let me know.
Modified by thorclark at 10:36 PM 5/5/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thorclark »</TD></TR><TR><TD CLASS="quote">I just did the same thing and im happy with it all I can get those skunk2 valves for 235 shipped lemee know. I also can get UGR valves skunk2 sister company for 185. Basicaly the same valve but a differnt name. Let me know.
Modified by thorclark at 10:36 PM 5/5/2008</TD></TR></TABLE>
ok!! i let you know
thanks
ok!! i let you know
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 »</TD></TR><TR><TD CLASS="quote">why do you need to replace your valves for 500whp? just curious. </TD></TR></TABLE>
probably i don't need to but i want to;
why???
because the valve steam seals are bad a lot of smoke 10s after i turn my car ON every morning , my cam seal plug is leaking and i need to remplace my timing belt since the motor has 115k with the stock one. i just installed my oil catch can so no more oil thru the pcv and valves.....
i said [freak] it my mecanic is going to open the head why don't upgrade with new stuff and replace all the seals, if i don't do it now he's gonna charge me my other leg next time againg, i'm just trying to save money
i don't want to touch the head after i get my sleeved block in about 3month
OOHH and i thought was a bad *** deal $900 (camshaft,cam-gears,spring,retainers)
thanks 4 asking^^^
why???because the valve steam seals are bad a lot of smoke 10s after i turn my car ON every morning , my cam seal plug is leaking and i need to remplace my timing belt since the motor has 115k with the stock one. i just installed my oil catch can so no more oil thru the pcv and valves.....
thanks 4 asking^^^
