Vtec Isn't Kicking in as Hard as it Used to ?
So i Just bought my GSR a couple Months ago, and the last Mod i put in it is the Password JDM CF Powerchamber Intake. Mostly Everything is Stock besides ITR Cams and ITR Exhaust Manifold. I Recently Lowered my Vtec Kick-in point at
L -> H = 4300
H -> L = 4800
with an Apex`i Vtec Controller. For Some Reason when i hit Vtec, it isn't kicking as hard or as loud as before. Could someone give me some Suggestions what could be wrong ? Thanks in advance.
L -> H = 4300
H -> L = 4800
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atmospheric SOUL »</TD></TR><TR><TD CLASS="quote">what butterfly ?
The dual stage intake manifold.
</TD></TR></TABLE>The dual stage intake manifold.
by lowering the vtec point you are changing the part of the powerband you switch into when going to the vtec cam profile. therefore when you go into vtec you are not producing as much power as you were before when you had the vtec set higher so it does not feel as strong when vtec engages.
Your vtec will not be as loud, and your ecu is not tuned properly to to engage there... You could get it tuned, and that would help a bit.. Put it back where it should be, and you will hear it fine.. unless you are low on oil.. That would cause vtec to engage half assed..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">Port the vtec solenoid </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThA5oLuTiOn »</TD></TR><TR><TD CLASS="quote">^^^i heared about that before. does that really works?</TD></TR></TABLE>
LAWL.
LAWL.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThA5oLuTiOn »</TD></TR><TR><TD CLASS="quote">^^^i heared about that before. does that really works?</TD></TR></TABLE> Yes, I gained 8 to the rear from it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper »</TD></TR><TR><TD CLASS="quote"> Yes, I gained 8 to the rear from it.</TD></TR></TABLE>
damn that **** is expensive I also heard machine shops can balance them so VTEC kicks in harder y0!
</TD></TR></TABLE>damn that **** is expensive I also heard machine shops can balance them so VTEC kicks in harder y0!
Hapa88
Apr 22, 2004 09:20 AM
