wire tuck on a 5h gen how to and any problems after
Just throwing this out there, but I took out the cruise control yesterday, took 10 mins at most.
Very simple and quick way to clean and remove a huge unit. Also saves 5lbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryukiori »</TD></TR><TR><TD CLASS="quote">i wanna do a wire tuck and was wondering how to do it and also any problems after the tuck and if i can get some pics as well thanks
It's as complicated as you want it to be, and there will only be problems if you screw up.
You can; remove extra stuff, cut/extend/shorten wires, modify wire harnesses so they are hidden, re-route wires (under fenders, behind firewall, under intake manifold, etc), move brake lines & fuel lines, and really do whatever you want.
Search in the Appearance/Cosmetic forum and you will find lots of pics.
</TD></TR></TABLE>It's as complicated as you want it to be, and there will only be problems if you screw up.
freeplay
Audio / Security / Video
24
Mar 13, 2004 09:06 AM
