Momo Tuner Steering Wheel, NRG hub and quick release..
I just got done putting together my steering wheel/hub/quick release. It came with no instructions and it looked like common sense. But afterwards I had these parts left over..any idea what they're for? One looks like some sort of spacer? And the others like a washer of some sort?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ritchie »</TD></TR><TR><TD CLASS="quote">Want to know as well.</TD></TR></TABLE>
i have the same set up and have no clue what those two pieces on the top with the holes do, but the thick metal ring is used to keep the horn in place. You only need to use that thick ring if you dont use the big ring that goes over the steering wheel. sounds confusing, but if you have the momo tuner wheel in front of you, you should know what i mean.
the thin rings are for grounds as nardi wheels only have 1 terminal on the horn button. you put on a terminal on the tab that sticks out. and it bolts between the qr and the wheel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20quang »</TD></TR><TR><TD CLASS="quote">i have the same set up and have no clue what those two pieces on the top with the holes do, but the thick metal ring is used to keep the horn in place. You only need to use that thick ring if you dont use the big ring that goes over the steering wheel. sounds confusing, but if you have the momo tuner wheel in front of you, you should know what i mean.</TD></TR></TABLE>
I know what you mean..at least I think so. Are you talking about the black ring that has the six screws going into it to hold the horn down? If that wasn't there then you would use the metal ring for?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newby_j »</TD></TR><TR><TD CLASS="quote">the thin rings are for grounds as nardi wheels only have 1 terminal on the horn button. you put on a terminal on the tab that sticks out. and it bolts between the qr and the wheel. </TD></TR></TABLE>
Okay cool, then I have no need for them since mine have enough terminals..
Thanks guys!!
Thanks guys!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96civic_hb »</TD></TR><TR><TD CLASS="quote">
Thanks guys!!</TD></TR></TABLE>
exactly, if you go without that ring, you need the thick washer or it will pop out
charlie0882004
13
Aug 26, 2008 09:51 PM
Captain JDM
Mar 13, 2007 10:49 AM
