Can i Boost her !!
Just did a compression test on my 1994 integra LS and my results were 167 , 165, 160 , and 170 can i safely boost my car with a t3/t4 50 trim turbo running some where between 6 - 10 psi.. this is still my daily driver and still has a stock bottom end thanks alot guys !!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P’cola GSR »</TD></TR><TR><TD CLASS="quote">sounds good, u should do it
X2
</TD></TR></TABLE>X2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">Yes.. #'s look good.
LS's are great with boost.. just make sure you get a good tuner..</TD></TR></TABLE>
I agree
I agree
thanx guys !! ill definately post up numbers and stuff when its all done ... i was just worried cause im new with boosted cars and the fact that i have 116k didnt no if that was too high of mileage thanks again guys !!
actually i had one other question too .. just to see what you guys thought do you guys recommend a different type of turbo ? or is the 50 trim the best way to go since im also lookin to keep this a daily driver ? thanks again !!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by millertime1085 »</TD></TR><TR><TD CLASS="quote">actually i had one other question too .. just to see what you guys thought do you guys recommend a different type of turbo ? or is the 50 trim the best way to go since im also lookin to keep this a daily driver ? thanks again !!</TD></TR></TABLE>
.50 trim should be fine.. i'd say it will spool up fairly quick
not looking to thread jack, but looks like this ones dead anyways. i tested my compression and the numbers i got on my da were 215, 205,205, 215. good for boost? i thought they were a little higher than most ls's. the car wasnt at operating temp so the actual numbers are probably different, it was just a quick test. im only running a small t3 at 7lbs of boost.
hey guys i was looking at some of these manifold downpipe combo kits wanted to see your thoughts ??
http://cgi.ebay.com/ebaymotors...ZWDVW
http://cgi.ebay.com/ebaymotors...WD10V
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmland »</TD></TR><TR><TD CLASS="quote">
X2</TD></TR></TABLE>
x3 and I also agree with<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickdrizzle »</TD></TR><TR><TD CLASS="quote">STAY AWAY FROM EBAY CRAP.</TD></TR></TABLE>
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmland »</TD></TR><TR><TD CLASS="quote">X2</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by millertime1085 »</TD></TR><TR><TD CLASS="quote">are there any good sites that you guys recommend for buying and putting together a good turbo kit ??</TD></TR></TABLE>
check out the force induction classifieds.
i was also possibly considering goin the mitsubishi 16g route ?? or do you guys like the t3/t4 50 trim or the t3/t4 57 trim route better ?? found a site thats sellin the 57 trim for $ 589 and the 50 trim for $ 665 and for a evo III 16g for $ 590 what do you guys prefer or think is the best route ??
http://www.roadraceengineering.com/eclturbos.htm
http://www.vsracing.net/catalo...78_80
