DA coolant leak help
Old May 5, 2008 | 05:10 AM
90blkteg's Avatar
Default DA coolant leak help
I have a DA and this morning I have a coolant leak and it s coming from behind the motor and I can't see it what is it?
Old May 5, 2008 | 07:03 AM
JETSPD1477's Avatar
Default Re: DA coolant leak help (90blkteg)
theres a few coolant lines behind and underneath the intake manifold. best bet is to get in there and discover it...
Old May 5, 2008 | 08:07 AM
91JDMTeggy's Avatar
Default Re: DA coolant leak help (JETSPD1477)
Yah theres a couple lines back there, i had a problem with mine but didnt know what it was. later found out it was my effin water pump. that sucked to change. haha
Old May 5, 2008 | 08:53 AM
90blkteg's Avatar
How many coolant lines are there under the intake manifold? Are they easy to get to?
Old May 5, 2008 | 10:26 AM
super jdm yo's Avatar
they're not really under the intake manifold. they're sorta to the side around the thermostat. there's only one that's under the intake manifold. they're all pretty easy to get to from the top. the one that's under you can get from the bottom by the oil filter
Old May 6, 2008 | 12:20 PM
90blkteg's Avatar
Default Re: DA coolant leak help (super jdm yo)
Thanks I found out which hose it was. It was the hose that goes from the throttle body to the head. It was ripped open as if someone took a bite out of it. Thanks once again.
Oxadiba
Aug 9, 2015 04:56 AM
Nobody123
Dec 22, 2011 05:16 PM
Mr.Chow
Jun 14, 2006 12:39 PM
si0385.
Dec 17, 2005 01:59 PM
