Need help with my swap!
Old May 4, 2008 | 11:16 PM
204hatch's Avatar
Default Need help with my swap!
I just swaped in a b18b obd1 motor into my 92 Civic cx hatch. The motor runs fine and starts but it wont go over 1500 rpm. When i give it gas it just boggs out and dies. The CEL is on and i dont know what it can be.
I did a compression test and it was 170 for all 4, i also changed the wires to NGK and NGK iridium IX plugs, and put the wires in the right plugs in the dizzy. I thoght it was the ECU so i hooked up my friends P75 and its the same thing.
I have no idea what it could be, any help or suggestions will be great.
I only have the headers on and no exhaust, can this be the problem?
thanks
Old May 4, 2008 | 11:34 PM
EFRue57's Avatar
Default Re: Need help with my swap! (204hatch)
why don't you check what code you are throwing? that would be the first place i'd start.
Modified by EFRue57 at 2:40 AM 5/5/2008
Old May 5, 2008 | 12:00 AM
JohnnyWash1's Avatar
Default Re: Need help with my swap! (EFRue57)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFRue57 &raquo;</TD></TR><TR><TD CLASS="quote">why don't you check what code you are throwing? that would be the first place i'd start.
Modified by EFRue57 at 2:40 AM 5/5/2008</TD></TR></TABLE>
+1
There's a how-to at the top of this forum
Old May 5, 2008 | 12:38 AM
AGP-EG's Avatar
Take your MAP sensor off on top of the throttle body and try running it with a seperate vacuum hose with a plastic T fitting between the FPR and the nipple on the middle of the intake manifold.
plastic vacuum hose T-fittings can be bought single or in packs for anywhere from 2-5$ at a auto parts store.
Old May 5, 2008 | 06:39 AM
204hatch's Avatar
These are the codes its flashing.
6 ECT - water temperature sensor
21 VTEC spool solenoid valve
Im not sure why its flashing the vtec spool solenoid valve since its a b18b
Do you guys think that i have the wrong harness?
Old May 5, 2008 | 06:58 AM
204hatch's Avatar
sorry that was wrong its actualy:
10 IAT - intake air temperature sensor
20 Electrical load detector
Old May 5, 2008 | 07:45 AM
hondateg10's Avatar
From: Somewhere in the United States, united states
Default Re: (204hatch)
have to tried putting the exhaust on?
Old May 5, 2008 | 09:04 AM
yozsi's Avatar
if you dont fix the ect sensor, the engine will never run right. probably one of the most important sensors for the ecu.
Old May 5, 2008 | 11:09 AM
eg6sirturbo's Avatar
Default Re: (yozsi)
take the whole motor out and toss it! drop a k20r and your good to go! jk
Old May 5, 2008 | 11:16 AM
AGP-EG's Avatar
so change out 6 and 10 and fix 20 later, it's not a big mystery changing out a couple small sensors, just be careful putting the new ones back on and don't overtighten them or you will break something.
Old May 5, 2008 | 12:33 PM
204hatch's Avatar
Default Re: (AGP-EG)
See the thing it i dont know where they are, they might just not be pluged in since i did install the harness myself and had alot of problems with it.
Where can i find these sensors?
Old May 5, 2008 | 04:34 PM
AGP-EG's Avatar
ECT is one of the two on the left side of the head, and IAT is white or black in color in the middle top of the intake manifold slightly to the right next to the FPR about.
Old May 5, 2008 | 10:18 PM
204hatch's Avatar
Could this also be a problem since im runnig a stock D15 alternator?
TurtleEF3
Aug 30, 2005 04:36 PM
jpangeles
Oct 13, 2004 06:57 PM
DriveSideWays
Aug 18, 2004 07:27 PM
XSSIVE
Nov 21, 2003 06:54 PM
Rob!
Apr 8, 2003 06:39 PM
