B16A2 sohc vs dohc ECU
Old Jul 13, 2002 | 04:30 PM
kaoticivic's Avatar
Default B16A2 sohc vs dohc ECU
I have a question, the guy doing my engine swap is trying to give me a SOHC VTEC ECU to run my DOHC VTEC, will this work, and if so will I lose power? Also how do I tell a JDM from a USDM?
[Modified by kaoticivic, 2:11 AM 7/14/2002]
Old Jul 13, 2002 | 09:44 PM
88crxoncrack's Avatar
Default Re: B16A2 sohc vs dohc ECU (kaoticivic)
you cannot use a sohc ecu to run a b16, you can use a P28, which is from a sohc motor (92-95 EX) but it has to be remapped, not stock.
Old Jul 16, 2002 | 05:55 PM
Kataku2K3's Avatar
Default Re: B16A2 sohc vs dohc ECU (88crxoncrack)
If the P28 is chipped i would take that if not the guy is tryin to **** you over. If it is a stock ECU you would have some fucked up mapping and a rev limiter at 7200rpm. See what he says
j.packsb
Engine Management and Tuning
Oct 30, 2009 09:47 AM
j.packsb
Oct 29, 2009 07:16 PM
I Gotta Question
Dec 21, 2002 11:00 PM
kaoticivic
Jul 13, 2002 08:46 PM
