help with my CRX
This car is beyond on my nerves. I took the head off because I thought maybe the valves were bent and well no bent valves. before I took the head off I was only getting power from 2 cylinders the 1-4th. now the head is off and I realized the valve lash was all [freak]ed up and now that is back to where it should be. now I need new head bolts and head gasket and a intake gasket. I am not sure what the deal is with this car. the wires are getting spark and the cap and rotor are new. I have 2 computers so that is not the problem is there any one out there that has any idea at all what in the hell is going on? this is nothing new wrenching on cars but I have never had a car bend me over like this one...
well if the valve lash was wack then it was probly not firing in those cylinders (2-3), also check to make sure your getting fuel in those cylinders, when you get it back together check the compression and see where its at.
