92 LS(obd-1)...should I go obd-0???
Old Jul 13, 2002 | 03:17 PM
EGHatchy's Avatar
Default 92 LS(obd-1)...should I go obd-0???
If the 92-93 LS(obd-1) motors are rated at 140 hp, and the 90-91 LS(obd-0) motors are rated at 130 hp...would I be losing power if I took my 92 LS and ran it obd-0???
Old Jul 13, 2002 | 04:58 PM
Malgerus's Avatar
Default Re: 92 LS(obd-1)...should I go obd-0??? (EGHatchy)
I wouldn't think that you'd lose all that much power, though maybe a little. You would get worse mileage and emissions running OBD-O though. It's up to you though.
Old Jul 13, 2002 | 05:32 PM
USDM 4G VTEC's Avatar
just run that 92 like it were a 91 OBDO engine... u wont loose any power..... and it will be good....
Old Jul 13, 2002 | 06:18 PM
4potnick's Avatar
Default Re: 92 LS(obd-1)...should I go obd-0??? (JDM EF9)
If i get a 92-93 motor which is obd1 can run it obd0 without problems.
Old Jul 13, 2002 | 06:37 PM
Default Re: 92 LS(obd-1)...should I go obd-0??? (4potnick)
they basically have the same sensors and same wiring plugs... i got a 93 Si mini me running it like a OBDO its all same plugs....
tego_integra
Mar 28, 2009 11:31 AM
schmiddr2
Apr 2, 2008 05:37 PM
DA_Manny
Jun 24, 2007 11:52 PM
XkjeldorX
Mar 15, 2006 05:51 PM
12SecHatch
Aug 17, 2004 10:18 AM
