difference between obd0 and obd1 b18a
Old Mar 14, 2006 | 06:53 PM
XkjeldorX's Avatar
Default difference between obd0 and obd1 b18a
i just bought a motor and was told it was a 93 but i just want to make sure. dont bash me cause i searched and didnt find it.
does anyone know how to tell the difference from a 92-93 obd1 b18a and a 91 obd0 b18a? the motor didnt come with a dizzy or alternator so those options are out.
hope someone out there can help me out. thanx
Old Mar 14, 2006 | 07:10 PM
XkjeldorX's Avatar
night bump
Old Mar 15, 2006 | 04:36 AM
XkjeldorX's Avatar
bumo... anyone
Old Mar 15, 2006 | 04:46 AM
crxnj's Avatar
Default Re: difference between obd0 and obd1 b18a (XkjeldorX)
Right above the exhaust ports there is a date..If it is a 93 head it should say 92 then 6-11 or 93 then ???
Also 92-93 B18a1 motors have more agressive cams and different intake manifold then 90-91..
Old Mar 15, 2006 | 05:51 AM
XkjeldorX's Avatar
Default Re: difference between obd0 and obd1 b18a (Mr.speaker)
what if it is stamped 9/1? does that mean is a 92 motor?
Old Mar 15, 2006 | 05:52 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XkjeldorX &raquo;</TD></TR><TR><TD CLASS="quote">what if it is stamped 9/1? does that mean is a 92 motor?</TD></TR></TABLE>
If it says 9/1 ,,then 6-11, that means its a 92 motor..
Old Mar 15, 2006 | 06:16 AM
XkjeldorX's Avatar
hope u can help me out. just went outside to look at the other numbers and these were it. starting from left to right, looking at the motor.
there is a 9/1, 1/0, 1/1 and the last one is either a 6/0 or 0/9
on the block it is stamped b18a1 and under that the numbers 3307740
on the head all the way to the left there is a number going up and down, that number is A111010764
can u tell me anything from this info?
Old Mar 15, 2006 | 06:29 AM
crxnj's Avatar
Im thinking its a 91 head..
You can also tell by looking at the vin# on the motor,,The 10th digit will tell you..
M = 1991
N = 1992
P = 1993
Old Mar 15, 2006 | 06:34 AM
Micha's Avatar
FAILWGN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">Im thinking its a 91 head..
M = 1991
N = 1992
P = 1993
Thanks a ton for this post, I just learned something new on Honda-tech. Yay.
Old Mar 15, 2006 | 06:39 AM
XkjeldorX's Avatar
M = 1991
N = 1992
P = 1993
well see i dont have the vin number from the motor thats why im trying to figure out by just things on the block and head.
Old Mar 15, 2006 | 06:58 AM
Danronian's Avatar
Yellow clearish plugs also point to OBD 0.
Old Mar 15, 2006 | 09:23 AM
AlexintegraGS-R's Avatar
the question is? what do want to do, the real difference about obd system is by generation, first off, obd stands for on board dianosic, meaning you can check if the car is running as it was design. as emission. the way you can tell the difference is you look on the plugs of the wiring harness, if the plugs are white for tan, thats obd 0, if they are grey, obd 1 or 2. as long is the same motor, it should work, no matter what year,, for ex b18a1 90-91 integra, b18a1 92-93 integra, both are the same motor but the both have different obd systems. as ecm just work differently..
Old Mar 15, 2006 | 10:02 AM
XkjeldorX's Avatar
Default Re: (AlexintegraGS-R)
i know there is no difference the thing is this motor is going into a 93 integra and i just want to know what year motor i have, i know if i have a obd 0 i can just make it obd 1 by switching injectors, dizzy and ecu, but i just want to know for myself so when i have to do something and year comes into play i'll know for sure.
what plugs are u tallking about AlexintegraGS-R? i dont have the dizzy, sparkplug wires or alternator, i do have the engine wire harness. can the engine harness tell me anything? thanx for trying to help out
Old Mar 15, 2006 | 12:15 PM
Danronian's Avatar
If any of the engine plugs on the engine harness are yellowish clear, its obd O.
Old Mar 15, 2006 | 05:51 PM
XkjeldorX's Avatar
Default Re: (Danronian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danronian &raquo;</TD></TR><TR><TD CLASS="quote">If any of the engine plugs on the engine harness are yellowish clear, its obd O.</TD></TR></TABLE>
got it. its obd 0, im guessing 91 from the stamp on the head. i just have to get dizzy, injectors and ecu now. thanx to everyone that helped me out.
xaine
17
Aug 18, 2008 04:20 PM
DA_Manny
Jun 24, 2007 11:52 PM
hatchydude
Mar 12, 2006 08:05 PM
mannyfresh2.0
Jan 24, 2006 05:22 AM
slowassciv33
Nov 3, 2005 02:38 PM
