DA front and rear brakes on an eg???
Old Jul 13, 2002 | 03:16 PM
ihaterice's Avatar
Default DA front and rear brakes on an eg???
will DA integra front and rear brakes bolt onto an eg??? just wondering, didn't know for sure
james
Old Jul 13, 2002 | 06:09 PM
drvfast's Avatar
Default Re: DA front and rear brakes on an eg??? (ihaterice)
yes
Old Jul 14, 2002 | 07:29 AM
EG Power's Avatar
New User
Default Re: DA front and rear brakes on an eg??? (drvfast)
Yes and no, I know for a fact that the DA front knuckles are not the same as EG/DC, which will result in uncorrectable negative camber. Believe me I tried the swap. As far as the rears go, you should prolly be able to swap the disc assembly over to your EG rear trailing arm if they are different, if they are the same, just bolt them up. Hope that helps.
Old Jul 14, 2002 | 07:48 AM
Plan B's Avatar
Default Re: DA front and rear brakes on an eg??? (EG Power)
what about the da ebrake cable?
Old Jul 14, 2002 | 08:17 AM
shawnhayes's Avatar
Refer:
https://honda-tech.com/zerothread?id=152884
Shawn
RACE2WARPED
Suspension & Brakes
Sep 28, 2010 06:33 PM
blk007
Suspension & Brakes
May 10, 2006 09:20 AM
drewbie
Sep 9, 2004 06:14 PM
al3e
Jan 6, 2004 12:53 PM
88civicHB703
Jun 2, 2003 07:08 PM
