b16 help plzzzzzzzzzz
Old May 4, 2008 | 12:30 PM
mrflak0's Avatar
Default b16 help plzzzzzzzzzz
i did a b16a swap in my 89 civic si and im runing the b16 obd1 injectors with the pig tails but the car wont run without the restistor box dose anyone know how to fix this
Old May 4, 2008 | 01:30 PM
MonkeyMagic's Avatar
Default Re: b16 help plzzzzzzzzzz (mrflak0)
if they plugged into the obd0 harness (clear plugs) then they aren't obd1 injectors
if you had to splice grey plugs into your harness... well it should run w/o injector box. but you can't just unplug the box.. you have to jump the yellow wire to all four red wires.
Old May 4, 2008 | 01:31 PM
zccr-xsi's Avatar
why u seing obd1 inj there all 240cc so it wont make a differance if your useing obd1 or obd0 inj.and if it wont run without the box means u got peak and hold inj. .only honda with bigger inj then 240 is the h22a. i would just stick with obd0 inj. i got some if u need them?
Old May 4, 2008 | 02:57 PM
mrflak0's Avatar
Default Re: (zccr-xsi)
yhea i spliced the clear clips with the grey clips i want 2 keep obd1 clips because im going to turbo later and am going to need obd1 clips
Old May 4, 2008 | 03:03 PM
zccr-xsi's Avatar
Default Re: (mrflak0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrflak0 &raquo;</TD></TR><TR><TD CLASS="quote">yhea i spliced the clear clips with the grey clips i want 2 keep obd1 clips because im going to turbo later and am going to need obd1 clips</TD></TR></TABLE>
well when useing dsm inj ull need the dsm clips,as with perscion and others,u might get lucky and find a set that fit stock clips.i was trying to save u the trouble of hacking up your harness.
lilsicsoul
Jan 22, 2009 09:31 PM
bigodub93
Jan 11, 2008 05:30 PM
keenspeed94
Apr 20, 2007 11:06 PM
SupraRXZ
Feb 3, 2006 02:15 PM
mr. Grind
Aug 13, 2004 04:08 PM
